Old 01-03-2014, 07:08 PM   #1
Wild_Alaskan's Avatar
Snowbike kit
Put it on today riding it tomorrow
Old 01-03-2014, 07:25 PM   #2
I am very jealous.
I have never ridden a snowbike I bet they are fun. Bring a lot of extra gas...
I often thought it would be great to ride a plated snowbike through town!
Old 01-03-2014, 08:25 PM   #3
I never thought of a DS snowbike! Epic!
Looking forward to video, WA.
Old 01-03-2014, 08:42 PM   #4
That is very cool. We eagerly await videos.
Old 01-08-2014, 12:06 PM   #5
OK, WA, we are still waiting for the pictures!
Old 01-08-2014, 03:35 PM   #6
katoranger's Avatar
He hasn't stopped riding it yet.
Old 01-08-2014, 03:47 PM   #7
OK OK here you go
The kit corners extremely well
hit a small jump
Unfortunately the bike seized a short while later, the next replate I'm going to request larger tolerances as this is the second time this has happened in under 40hrs run time
Old 01-08-2014, 06:06 PM   #8
Pics look great. I was wondering how hard it would be to turn. Sorry it siezed but at least two stroke semi cheap and easy to replace top end. Snow tracks put a severe load on an engine.
Old 01-08-2014, 06:22 PM   #9
I'm sorry to hear of the seizure. I hadn't thought of it before, but I'm sure a snowtrack does put a large load on an engine.
Old 01-09-2014, 12:33 AM   #10
Bummer about the seizure. By larger tolerances, do you mean the piston to cylinder relationship? If so, I'm not sure how far you could go before encountering piston slap.
Old 01-09-2014, 11:35 AM   #11
I doubt it would need much the difference between seizing and running good is very very small. My guess is these bike have a clearance set up for typical low rpm low load use.
Old 01-09-2014, 11:40 PM   #12
I agree. Since a typical overbore is 0.5mm, you'd want to be inside of that number.
Old 01-13-2014, 12:18 PM   #13
standard clearance for a cast piston is .05 to .07mm, i will be talking to the technician at us chrome when my cylinder arrives about how much bigger would be necessary. I would guess it will be in the .1mm range
Old 01-13-2014, 12:46 PM   #14
I wonder if 4 strokes pull snowbike kits better/more reliably due to low end torque?
Old 01-13-2014, 01:30 PM   #15
Most track kits are pulled by 450 four strokes. likely because that's whats available, and 250 two strokes don't have the power needed to pull a track, The 380 makes similar power to a 450 without a valve train. I think a purpose built 380 will easily be more reliable and of equal performance of a typical 450.
A 380 ported for max power could easily over power a 450 at the expense of some low end, but that would negatively impact putting around tight and gnarly single track.
