Old 07-15-2013, 02:46 PM   #1
satelliteone   satelliteone is offline
Rebuild of the skyjet SJ125 GY-6
Hi all, been a while, not long ago bought a skyjet 125. Dead cheap and on a 2008 plate. Here in the uk. using the cg125 156fmi pushrod engine.
The bike was well worn covered 12 thousand miles already. but was in dire need of repair. The engine was wobbling around in the mounts when changing gears, later on investigation the mounts had broke from the frame. I have stripped the bike down to the frame and rewelded. also one of the mounts has cracked the case at the rear, I small puddle of oil under the engine. now fixed.
Whilst the engine was out, it was stripped down, split the case, and then tig`ed.
so here is the bike, when I got it.
Been buying new bits here and there, better bars and grips, 17t front sprocket, new chain, even new valves. as the old ones were pitted due to being badly adjusted.
Old 07-15-2013, 02:47 PM   #2
Old 07-15-2013, 02:54 PM   #3
This is a great project! Thank you for documenting you work with photographs, and sharing it with us.
I have moved your thread to the Dual Sport Forum where it will deservedly receive greater exposure.
Old 07-15-2013, 03:15 PM   #4
cheeeers spud..
been doing a little more. today. the suspension is back on.
the bar risers repainted. the yokes now proper set and regreased
Old 07-15-2013, 10:01 PM   #5
You're really transforming that bike. I like the socket head cap screws on the rear sprocket; are they stainless?
Old 07-16-2013, 01:58 AM   #6
You're making good progress.
Old 07-16-2013, 01:01 PM   #7
weldngrind. aweome name.. yeah they are. replacing/upgrading as I go. any suspect bolts are changed. lockthreaded as I go too.
ta spud.
some more pix of today. engine is finished and installed. mudguard is back on.
Old 07-16-2013, 01:51 PM   #8
We love photos; thanks for posting them. Did you install new grips? If so, what brand?
Old 07-16-2013, 03:19 PM   #9
using pro grip spud. ebay the all mighty parts department.. lol
http://www.ebay.co.uk/itm/NEW-GEL-TO...item337161c1c5
another evening in the spare room. just finished installing the magneto cover and front 17 tooth sprocket, original was 16 tooth. should be slightly better for cruising. awaiting the 428 130 link chain in the post. next is the brakes.
Old 07-17-2013, 12:45 AM   #10
Almost a whole bike again. What are you doing with the magneto cover?
As a point of interest, another fine member from the UK found an 18 tooth sprocket, but that might be a bit much for your application.
Old 07-17-2013, 06:30 AM   #11
just refitting weld, more stainless bolts too..lol.. my new headlamp turned up in the post this morning, so new pix later today.
Old 07-17-2013, 06:46 AM   #12
Old 07-17-2013, 10:37 AM   #13
I think that's the same headlight I just bought. May we see how you mounted yours?
Old 07-17-2013, 05:05 PM   #14
when I get the camera out, I shall weld...night off for now, back on the rebuild morra
Old 07-31-2013, 02:48 PM   #15
hi weld, they jus fit against the clocks, the two clipable rubber straps around the top of the forks.
pretty much finished the bike.
