03-10-2013, 01:18 AM | #1 |
Project Zongshen Sierra
I just bought a 2006 Zongshen Sierra non running, tomorrow will be the first day i start on my project bike. Unfortunately I know very little on Enduro's let alone a Zongshen, I dont know whether to use synthetic or regular oil in my bike. And is it even possible to switch from regular to synthetic? if so, what are the steps into doing so? I've always admired the Zong, Since it was the first bike i learned to ride on. Also what would be the best way to clean out my Carburetor. Luckily for me i live 20minutes away from Zongshen America. parts are not the issue in my case, knowledge is. `
thanks, Kidd |
03-10-2013, 01:32 AM | #2 |
Oh, no. Do you know what you just did? You started another dreaded oil debate.
Several of us have converted to 15W40 diesel oil, of whatever brand is on sale. Lately, I've been using Rotella, which I get for cheap at Walmart. Yes, you can switch from synthetic to conventional. Just drain the old oil out and add whatever you wish. Make sure that you clean the filter and screen properly, and install the filter in the correct direction. http://chinariders.net/modules.php?n...ewtopic&t=7415
03-10-2013, 01:54 AM | #3 | |
03-10-2013, 03:38 AM | #4 |
It is a non-energy conserving oil, so it's suitable for use with motorcycle wet clutches. The only advantage over synthetic oil is the price.
BTW, Spud has more than 50,000 miles on his Zong, and he uses 15W40 diesel oil.
03-10-2013, 03:53 AM | #5 |
As usual, I agree with Weld. I also like the 15W/40, diesel motor oil. It's excellent motor oil, but the price is very reasonable, because the oil refineries sell so much of this oil to commercial trucking operations.
However, any good motor oil will work well in your Zong, as long as it's not "energy conserving" oil, which will cause your bike's clutch to slip. The most important thing is to change you motor oil every 1,000 miles, and clean the oil filter with each oil change. Spud
03-10-2013, 05:02 PM | #6 | |
03-10-2013, 09:09 PM | #7 |
Thanks for the good update! I'm glad your Zong is running.
03-10-2013, 09:33 PM | #8 | |
03-10-2013, 09:46 PM | #9 |
03-11-2013, 02:52 AM | #10 |
Thanks for posting the photos.
If appears you need a cover for the air box. Don't ride the bike without an air filter installed, or you will suck dirt into the engine. The dirt will damage your intake valve, valve seat, and the piston rings. :( You can buy an entire air box from Taobao; however, I would first check with Zongshen America. Another option is to put a pod filter on the intake of the carburetor. I'm glad you got the carburetor re-assembled correctly. You've got to be careful to get the slide diaphragm seated properly in the top of the carburetor. Spud
03-11-2013, 07:57 AM | #11 |
looks like the chain needs oiling
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
03-11-2013, 09:55 AM | #12 | |
i bought the filter from a local motorcycle shop, the reason why the picture has it off is because the old filter was nasty & falling apart. but ive got everything now |
03-11-2013, 10:27 AM | #13 |
03-11-2013, 10:29 AM | #14 |
Gotta love tailgate work benches.
I'd get rid of that chain and just replace it. Spud has researched this topic to an amazing extent, so the Zong sticky can provide you with all of the info you need. That tank is very familiar to me; I'm using Spud's old Zong tank on my TW.
03-11-2013, 11:23 AM | #15 | |
