10-15-2012, 01:46 PM | #1 |
Bike cut off and now not starting
Good day to all you experienced zong owners. I have a problem with my bike. I noticed very early this morning when I first started the bike it moved a bit sluggishly at first then it was fine. I parked at the location where I was going, the rain came down. After the rain I started the bike with no problem, rode about two blocks and the bike cut off and would not start anymore.
I am now charging the battery so I could test for spark at the plug. I know I will have to also check my Cdi but I don't know how to test it. Is there anything else that I can check. It has fuel. I drained the carb to see if it was full and it seems ok. Any help would be greatly appreciated. Thanks
ALWAYS ENJOY THE RIDE, YOUNG OR OLD<br /> |
10-15-2012, 02:41 PM | #2 |
A CDI could do this.
They are hard to test. The best way is to always have a backup 'known good unit' to swap out at times like this. You will need, AFAIK, a Zong specific one. Not expensive. Go to the Zongsite and there is a number to call. Be aware sometimes a CDI will fail intermittantly at first before it tries to strand you...
Happy to serve. |
10-15-2012, 05:02 PM | #3 |
Would that be zongshen America? Also I removed the plug and put it close to the engine block and there is no fire. Wil I be able to test the Cdi if I ha e a circuit tester? I will check for connectivity from the kill switch through the alarm system then down to the coil. I know I will have to pass through the Cdi to do this but does anyone know a specific way to test the unit. Should I be seeing power through the tester wile trying to start if testing the Cdi ? I will try to find the diagram of the Cdi wiring that I saw in another post also. This may help me. Any other suggestions will be greatly appreciated.
Thanks agaain
10-15-2012, 05:29 PM | #4 |
No spark is most likely cdi or the pickup coil. However sometimes my zong just doesn't like heavy rain and will shut off and not start. Then when it dries out it will start right up and run fine.
But yes, call the # on the zongshen america site. |
10-15-2012, 08:48 PM | #5 |
I will call the number but any suggestions on how to test the Cdi and pickup coil? I will be buying a Cdi in any event but I would like to try testing. I might be able to find the problem and get it running.
Thanks again
10-15-2012, 09:28 PM | #6 |
I noticed you said you put the plug close to the block, you have to actually hold it firmly against the block or head to get a good ground and then see if you have spark at the electrode. Apologies if this is the way you tested it and I just misunderstood
10-16-2012, 01:14 AM | #7 |
I suspect your CDI unit has failed. You cannot test the CDI unit, itself, other than to replace it with a known, good CDI unit. I suggest you purchase a spare CDI unit from Zongshen America. A spare CDI unit greatly facilitates troubleshooting the bike's electrical system.
10-16-2012, 01:16 AM | #8 |
You should measure the resistance of the pulse coil and pickup coil with a digital multimeter. The resistance values are listed in the Yamaha, TW200 Service Manual.
10-16-2012, 02:53 PM | #9 |
Ok guys thanks very much. I will test the resistance also. Does the company ship quickly? I don't want to be down too long. Also are there other parts I should order to keep on hand, as long as they Arnt too expensive. Thanks again to all of you. This will be a great Oppertunity for me to educate myself a bit more about my machine.
10-16-2012, 03:08 PM | #10 | |
I think Zongshen America is shipping faster than they did previously. Ask them to ship the CDI unit as quickly as possible, and call them every day until they confirm they have shipped it out to you. The only other place to get a Zongshen CDI unit is China, and they will certainly take longer to get it to you than Zongshen America. You might consider ordering some spare, ABS, upper side covers. You might also wish to order a pair of front brake pads and some spare cables. I would also order a few, spare, foam air filters, if you can get them. Spud
10-16-2012, 07:26 PM | #11 |
I had to get a new CDI at the start of summer I was worried I wouldnt get to ride this year. To my delight Zongshen America had me my new part in like a week. Very easy to deal with, was a little worried when they faxed me an order form and it was some what "generic" but Every thing was fine.
10-16-2012, 08:51 PM | #12 |
I called the number listed on the website but kept getting an automated system and the operator is not available. And they say to dial 412 for the directory but it doesn't work, I will try again tomorrow. Any idea how much a Cdi will cost from zongshenamerica? Also do they carry the cables and plastics.
I was also trying everything I could to see how to order from taobao trends but cannot get the URL to paste and submit, spud did you get to order the stuff I read you wanted to order from them or anyone else was successful recently, if so pls instruct how. I would like to order some extra parts to keep on hand, I refuse to be without service again, Thanks guys
10-16-2012, 09:11 PM | #13 |
What number did you dial? If you dialed the correct phone number, Zongshen America is probably having temporary phone problems. Ask them about the parts you wish to buy; they will know if they carry those items. Search this forum for a thread posted by Pliskin; it will tell you how to order from Taobao.
10-17-2012, 04:49 AM | #14 |
Pabesco, I would follow Spud's advice and try ZongshenAmerica first. But if you want to try taobao, you can read this link. http://www.chinariders.com/modules.p...hlight=pliskin
Zongshen 200gy-2 |
10-17-2012, 07:51 PM | #15 |
thanks alot to you guys, i was able to speak with someone from zongshen america today and was told the cdi will cost $54 including shipping to fort lauderdale, so i asked for the form to be sent to me via email so i could print it and send back via fax with creditcard payment today, im yet to get the form, ill call again tomorrow to see if i can get it sorted out
they said that they will ship the same day and i should recieve by the following day, thanks guys also i was able to setup an order at taobao and the prices are much much better than anywhere else, even including agent costs and in ternational shipping i will post exactly what i was interested in ordering along with the pricing, maybe others might want to order a few things too
