Old 02-19-2012, 02:52 PM   #1
cat-chevymech   cat-chevymech is offline
high speed miss
When i get around 7k rpm and above it bucks and feels like it is missfiring does anybody have any recomendationsit only does it in 4th and 5th[/img]
Old 02-19-2012, 03:22 PM   #2
Hitting rev limiter?
Old 02-19-2012, 03:46 PM   #3
Maby but it doesent feel like the chatter box cause i can hit 9k down hill light throttle its when im 1/2 throttle or more
Old 02-19-2012, 03:51 PM   #4
It misses
Old 02-20-2012, 09:10 PM   #5
Wild_Alaskan's Avatar
clean the air filter, change the spark plug, make sure main jet is still screwed in in carb.
Old 02-20-2012, 09:35 PM   #6
dsrt4   dsrt4 is offline
Check your valve gap lately?
Old 02-20-2012, 10:21 PM   #7
Sounds like valve float.
Old 02-25-2012, 08:56 PM   #8
ok ill check the valves
Thank you
Old 02-26-2012, 12:55 AM   #9
First check the items suggested by others. If you still have the problem, I suspect your CDI unit might be failing.
