Old 11-18-2011, 08:21 PM   #1
goofyexponent   goofyexponent is offline
Gio X31 build-up thread
Ok, for those of you who have followed my few posts, You know what I am all about. Do it once, do it right and enjoy a cold one instead of doing the job twice!
I bought my Gio x31, never had much of a problem with it.
Right out of the box it got a GOOD carb cleaning and new fuel lines with a good filter.
Then it got lights and a switch.
It just got new sprocket bolts and a good thourough carb cleaning and suspension lubing.
This winter I am going ALL out!!
I am stripping the bike down to the bare frame and it is being sandblasted and powercoated with a nice baby blue glossy finish.
I just ordered an 18 tooth front drive sprocket...that will increase the top speed a tad. I am going to TRY and get my hands on a higher compression piston....maybe 10 - 11:1 to up the ante a little with the name brands lol.
The front tire on the bike is just like new, but I am not so crazy about the drive tire....I am going to replace it with a Kenda Millville....Might do both to say it's done.
I already got my red plastics ordered, and I am going to drop them off to my buddy who is going to have his dad's sign shop sticker them up to look EXACELY like the older CR honda's graphics.
Once the frame is done, the bike is being assembeled with ALL hardened stainless fasteners.....and about a gallon of blue loctite lol.
Any opinions or ideas will be welcomed on this. I am always looking for ways to improve things....some say it's why I have no fingernails and permanent grease stains on my hands.
I shouldn't have ANY problem doing this ability wise, but time will be a factor. I am also building a de-compressed, hot pumped, BIG single turboed, intercooled 7.3 mechanically indriectly injected diesel....not a powerstroke, but one of the old non turbo International diesel engines that used to come in the Ford pickups. I am shooting for 400 flywheel horsepower in her and I am dropping that into a 1994 F350 crew cab long box that I am converting from gas, automatic 2wd to a diesel, standard 4x4 with all rebuild parts..
..I don't know why I do these kinds of things to myself lol.
Gio X31 Paid $440 for the bike new in the crate! Currently a modified, high compression, head turning MONSTER!
Old 11-18-2011, 09:36 PM   #2
I really look forward to following your progress.
BTW, I really love Halifax. I've done a lot of riding up there, I had a girlfriend from there also :wink: . Beautiful city, and a beautiful Province. Great riding.
Old 11-18-2011, 10:12 PM   #3
Sounds like you've been hitting the Newfie Screech. Excellent.
Beware that stainless fasteners are only about grade 2 in regular SAE bolt speak. I totally agree with stainless stuff for non-tensile loads, but you might need to choose grade 5 or 8 for some stuff, like motor mounts. Whether stainless or not, I use socket head cap screws wherever I can.
Lets talk torque. How much will the International make? I think that the 7.3 was the pre-'04 motor, IIRC. Do you have a donor diesel truck that will give up the trans, etc? What turbo will you use? Factory wastegate or adjustable? I'm gonna geek out over both of these projects, and I hope you start a new thread for the truck.
Old 11-19-2011, 06:40 AM   #4
WEll, the 7.3 I have came into play in 1988. Previous to that it was a 6.9 and it came into the picture in 1983. The 6.9 and the 7.3 are virtually the same engine, just the bore on a 6.9 is 4" even and the bore on a 7.3 is 4.11". Both have the same 4.1" stroke and share EVERY other part besides the pistons and head bolts.
These engine went off the market in 1994.5 when international decided to release the electronic, direct injected powerstroke which had 3 generations from 1994.5 through to 2003 when it was dropped in favor of the poison 6.0 powerstroke....that engine was pure junk.
But back to my IDI engine. Its 100% mechanical. I can jump start it with litterally just a 14 gauge wire off a battery and it will run no problem.....try THAT with a powerstroke! LOL
I am guessing that my torque will be around the 700 - 750 ft. lbs mark. Factory my engine would have only made 190 horses and 370 ft. lbs. of torque.
I have an ATS 093 wastegated turbo setup currently. I can run it to about 25 PSI but anymore than tha t and it will start to choke itself out for power.
She is having a set of pistons made specially with the wrist pin 30 thousandths higher on the piston to lower the compression. As it is indirect injection, there is a pre-combustion chamber in the head. I am porting them puppies WIDE open and doing a little port work on the heads intane and exhaust runners. She is getting an aggressive cam, ARP head studs to hold the heads on and an intercooler out of a freightliner M2-106. Along with a hot "Moose" pump and a brand new set of pressure matched BB injectors.....stage 1 sticks from DPS.
I got the truck I am driving now which has a PILE of work done to it. It's not performance work, but ruggedness work. She has had a 5 speed ZF s5-47 transmission swap to replace the E4OD automatic, dana 60 front axle swap and both driveshafts built from scratch to make up for the difference in length between teh tranny and axle swaps.
When the time comes, I am parking both trucks side by side and goin to town. The blue F250 I got is coming apart and all the parts I need are going on the red F350.
F350 pics
http://www.facebook.com/media/set/?s...1&l=ea3edc27d8
F250 pics
http://www.facebook.com/media/set/?s...1&l=b835ede37d
The F250 ati't much to look at, but it regularly hands me 22 - 25 MPG's and while in 4 wheel drive, there ain't much that can stand in her way!
Old 11-19-2011, 02:15 PM   #5
Oh man, I'm beggin' you to start a new thread! I especially like the photo with all the concrete pilings in the box; from the thumbnail pic, I though those were wine corks!
I had NO IDEA that ZF made transmissions for applications like that. I thought they were all about sports cars. It makes sense though, since the Germans are big into diesel stuff, so ZF has probably been making truck transmissions for a long time.
I'm not as familiar with diesel speak as I am gas, so here goes: instead of custom pistons, could you have 0.030" flycut from the stock-style piston? Would that weaken the piston significantly or perhaps get the ring lands too close to the top?
My Dad has a 2003 Powerstroke, and it continues to live. He's a complete hillbilly (which really begins to explain me), and he punishes his truck in Alberta. I'm gonna guess that he has in excess of 400000km on it, and it still makes impressive power. I've read several horror stories about the 6.0, yet his still makes smoke. I agree that they're hard-starting, but his always does. I guess there are always exceptions to the rule, but I'd still take the IH. 8)
Old 11-19-2011, 02:23 PM   #6
Im only familiar with ZF transmissions on BMW's and Corvettes. I don't know if the current Corvettes use ZF manual transmissions but my 1996 C4 does. Very strong transmission, but with straight cut, non-helical gears, not very quiet. Kinda like a truck tranny. :wink:
Old 11-19-2011, 08:35 PM   #7
I certainly can start a new thread once parts and pieces arrive. The reason why I am going with the new pistons is due to two of my pistons having stress fractures in the top. I am going to have the new ones ceramic coated as well, help with the heat distribution and durability.
The motor in that blue F250 has 524 000 kilometers on her. NOT ONCE has a head, valve pan cover or any major been off her. It's untouched and it runs as good as the day it was bought. burns 1/2 a quart of oil between oil change intervals of 5000 kilometers. $80 will take me right around 450 - 500 kilometers of mixed city and highway driving. I absolutely LOVE this truck. She ain't a show truck, but it's 8000 pounds of Canadian Muscle I will NEVER give up. That's right, not an american truck...she was built in Ontario back in 1992 as a 1993 model!
Old 11-29-2011, 04:00 PM   #8
Ok, the Red body kit arrived yesterday along with the 18 tooth front drive sprocket. But due to my good nature and willingness to help friends out, I wasn't able to put them on the bike until today. I wound up making a 500 kilometer trek across Nova Scotia, right after work yesterday with the F250 and a car trailer to retrieve a full size loncoln continental.....THAT was fun!
Anywho, I stuck the sprocket on the bike today and WOW! What a difference. I think it will be no good in the tight trails anymore, but I figgure it will do 70 MPH now...without too much trouble power wise.
This is how I did the math. http://www.gearingcommander.com/
Top speed on a stock 15 tooth front sprocket is a mere 58 MPH....nothing to laugh at, but I will STOMP ANY stock gio x31, 35 or 37 in a drag race now. First isn't as deep as I'd like, but it's not bad....closer to second dear on a stock bike but not as tall.
The thing FLIES now. I can't wait to tear into the engine with a big bore kit (possibility) or just a high compression piston (of which I am having a HECK of a hard time locating)
Cna anyone point me to the right direction of a big bore kit/high compression piston for a 2011 Gio x31...overhead cam engine.
I found gasket kits, but I need the actual hardware to fit her.
Old 11-29-2011, 04:09 PM   #9
I'm kinda surprised that you have room for an 18 tooth sprocket. Are you running without the cover? Not sure about where to find big bore stuff, but I'd be looking to Honda aftermarket bits. Do you know what the bore is now? I'll bet you can find a Wiseco that would meet your needs. If it helps, I can always measure an old XR200R piston, to help you determine wrist pin diameter, ring land height, skirt height, etc. I presume that your engine is a two-valve OHC, not four.
What year was the Continental?
Old 11-30-2011, 05:55 AM   #10
When I first stuck the 18 tooth sprocket in there and held the cover up by hanbd I heard metal on metal....GREAT!
But after I pulled the cover back off I seen a little dirt in there...I cleaned it out with a wire brush and it went away. Provided I keep the chain adjusted JUST right it JUST clears. 17 tooth would be a much better fit though.
I am not 100% certain on the bore size. I have read places that it is 65.5MM, others claim it to be 69MM and a few other sites range it anywheres in between. I can find ALL kinds of parts for smaller engines, but hardly any kits for the 250 engines.
I am not 100% on it, but I think the car was a 1996. She was a big old boat that's for sure! I had to haul it up highway 103 through the hilly area along the east coast, then down the 107 to the end of that....what a long haul!
Old 11-30-2011, 11:03 AM   #11
There's no soul in a '96. I would have left it for dead. The '71 Mark III had style.
There is no way to be sure about bore size until you tear into it. The stamping on the left side (near the gearshift) is an indicator, but it could be wrong. Since you have the gaskets, you might choose to pull the piston and see what aftermarket Honda solutions you can find. Again, I bet there's a Wiseco out there with the compression you're after.
Old 11-30-2011, 11:39 AM   #12
+1
Old 01-02-2012, 01:17 PM   #13
Well, I had the bike up for sale/trade on Kijiji due to me needing another vehicle.
The BS replies I got from IDIOTS out there was unreal. Some people email and offer me $200, $500....some people offer me a beat to death not running car, truck or video game consoles. I never replied to any of them.
Starting this weekend, the teardown begins. I am stripping the ENTIRE bike down, putting the parts in bags and going ahead with the build.
Frame being sprayed with a QUALITY enamel base clear.
I couldn't find a big bore kit, but I am in the process of confirming a high compression piston. A little off the head and it will MAKE SURE I am in the 11 - 11.5 to 1 range.
I will post pics of the ENTIRE build up from first bolt removed, to last bolt installed.
Wish me luck!
Old 01-02-2012, 05:49 PM   #14
Sorry to hear about the goofballs who responded to your ad. That said, I'm very interested to see how this build goes. I love polishing these turds into something fun and useful.
Old 01-08-2012, 10:25 AM   #15
Well, I got up this morning and headed straight to the garage.
The engine is OUT of the bike, and the top end is completely off it. I couldn't see any timimg marks on the case, so I made one when I had everything lined up. Small notch to judge by. The timing mark has to be in a straight line with the cam, with the timing mark on the cam to the left of the bolts at 90* to TDC.
What I want to do is install a high compression piston, port and polish the intake and exhaust runners in the head, check the deck and head for trueness and install with a new set of gaskets. Performance CDI, coil and stator to make sure I am getting optimum spark.
This engine is going to RUN when I am done.
I need to measure the piston and wrist pin and go on the hunt for a piston. Any help here would be GREATLY appriciated as I do not know of any reputable shops online to get performance parts from.
Pics in my FB album, feel free to add me on FB if you want.
http://www.facebook.com/media/set/?s...1&l=ccc8030b71
