08-18-2020, 11:52 AM | #1 |
Vader 125cc engine bolt sizes?
I keep hearing this should be one of the first things to change out as they break easy? Can you guys give me direction on what type you guys bought and what sizes? Are there just 2 or 3 bolts?
08-18-2020, 11:56 AM | #2 |
Simple. Just measure the bolts you have and go to the local hardware store or on line like Fastenal and order Class 8.8 grade bolts.
08-18-2020, 12:30 PM | #3 |
On my Hellcat 125...there is only 2 engine mount bolts. I used 5/16 x 5 in, grade 8 bolts/nuts/washers. The 5 in bolt was a little longer than necessary but I was able to trim some threads off for a perfect fit... and the 5 in bolt had a longer shank (no threads) part compared to the 4.5 in bolt... so maybe a tad stronger.
'20 TaoTao Hellcat 125 "grommet" '04 Yamaha TTR-125LE '00 Yamaha TTR-90 '07 Kinroad XT200GY Runmaster (sold) '07 KMD GY6 150cc ATV (sold) '07 Kangchao 250cc ATV Monster (sold) Baja Moto DB-30 "Doodlebugs"(x3) (sold) '06 Hi-Bird 200 parts bike (sold) |
08-18-2020, 04:03 PM | #4 |
Thanks guys, I just needed an idea on what to get.
12-19-2020, 04:51 AM | #5 |
I thought I'd read they were 110mm and 140mm. Haven't removed mine. They are black M8 hex head cap screws marked 12.9. I don't know where they were purchased, Powersportsmax put them in before delivery.
