Old 01-14-2018, 02:37 PM   #1
Saulflores   Saulflores is offline
The right turn signals arnt working, yea everything is wired correctly
The right turn signals on my new hawk are not working everything else is working fine but when i go to turn on the right turn signal the bulb in the head light turns one, everything is color coded and wired correctly, any ideas on what the issue is?
Old 01-14-2018, 03:46 PM   #2
ben2go   ben2go is offline
Blown bulb(s) or bad sockets.
Old 01-14-2018, 05:25 PM   #3
Azhule   Azhule is offline
If it's not the bulbs...
My guess would be to check for bad connection/solder points on the switch?
Old 01-14-2018, 09:35 PM   #4
kirbo7106's Avatar
Swap the left turn signals over to the right side. If they work, it’s somewhere in the turn signal. If not, swap the right side turn signals over to the left side just to make sure they work. If they work, at least you know the turn signals are good. After that, get a volt meter.
Keep us posted!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 01-14-2018, 11:54 PM   #5
humanbeing's Avatar
Originally Posted by kirbo7106 View Post
...After that, get a volt meter...
Or something that lights up http://f650.com/forum/showthread.php...l=1#post109116 Those Bi-color LED thingy is handy enough
http://www.dansmc.com/electricaltesting.htm had good tips
