01-14-2018, 02:37 PM | #1 |
The right turn signals arnt working, yea everything is wired correctly
The right turn signals on my new hawk are not working everything else is working fine but when i go to turn on the right turn signal the bulb in the head light turns one, everything is color coded and wired correctly, any ideas on what the issue is?
01-14-2018, 03:46 PM | #2 |
Blown bulb(s) or bad sockets.
01-14-2018, 05:25 PM | #3 |
If it's not the bulbs...
My guess would be to check for bad connection/solder points on the switch?
01-14-2018, 09:35 PM | #4 |
Swap the left turn signals over to the right side. If they work, it’s somewhere in the turn signal. If not, swap the right side turn signals over to the left side just to make sure they work. If they work, at least you know the turn signals are good. After that, get a volt meter.
Keep us posted!
01-14-2018, 11:54 PM | #5 |
Or something that lights up http://f650.com/forum/showthread.php...l=1#post109116 Those Bi-color LED thingy is handy enough
http://www.dansmc.com/electricaltesting.htm had good tips
