04-01-2016, 08:52 PM | #31 |
Culcune, elegantly stated.
04-01-2016, 10:01 PM | #32 | |||
Since you didn't understand my position, I will state it one more time. I strongly suggest anyone who is considering the purchase of a Hawk should make sure the bike he orders does not have this serious defect with the air box. If he isn't guaranteed the defect is not present, I think he is well advised to purchase a TT250, which is made by Zongshen, and backed by the excellent customer service from CSC.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 04-02-2016 at 05:02 AM. |
04-01-2016, 10:22 PM | #33 | |
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid |
04-01-2016, 10:46 PM | #34 | |
04-01-2016, 11:30 PM | #35 |
I am confused what defect you guys are saying something about a gap or something in the airbox hose. what is the specific defect and do I have it? In my pics there is no gap and there is a flange or lip on both sides of the airbox.
Lee 2014 powermax 150. 2015 Hawk 250. Poop happens |
04-01-2016, 11:35 PM | #36 |
Your bike is fine. I'm glad to know you don't have the defective air box. I sincerely hope this problem is rare. At this time I have only seen this problem reported by Wolftrax.
04-01-2016, 11:56 PM | #37 |
Ok thank you I was kinda confused I wanna see if I can get to your 70,000 km that you got with your old zong.
04-02-2016, 12:18 AM | #38 |
LOL! Spud, after the "burial at sea" for your Zong, I can see how water tight may be a concern for you! ;-)
I'm going to check out the TT filter setup closely upon arrival. If it just looks like a bunch of weight and the usual China box, I'm going with another K&N pod. From the filter tutorial though, it looks almost as nice a box as Q. Seeing it live will tell. Heck, once it's here, it's getting the major once-over on the lift as soon as it's uncrated. It may need a few beers and some hemming and hawing too.. Adding a new lady to the Harem. It's not like you can accept just ANYONE!
04-02-2016, 12:35 AM | #39 | |
I also had a short tube on my bashan, caught it and extended it with a 1 1/4 " pvc coupler and a hot air gun to extend the tube (tube is kinked somewhat but breaths fine) That is not rubber for sure , mostly like thick vinyl material. It needs a better solution however like the cone filter.
04-02-2016, 02:09 AM | #40 | ||
Personally, I don't like the weight of the pod filter hanging on the carburetor and intake manifold. Also, I have two bikes with CV (constant velocity) carburetors, and CV carburetors are designed to work properly only when fitted with an air box. I also like to vent the crankcase gases into a sealed air box, rather than have the crankcase vent hose exposed to suck water and dirt into the crankcase. Also, even in the rain, the air filter is better protected inside an air box. Exposure to moisture only gets worse when crossing streams, et cetera, with a pod air filter. Finally, I am poorly impressed with an improperly designed frame which won't connect the air box securely to the carburetor. This is the type of manufacture which generates ridicule for Chinese motorcycles on Thumpertalk, ADVrider, and other forums. I understand there is a wide variety of design control and quality control from different Chinese manufacturers. However, I own two Zongshen motorcycles, and I would never expect to see this kind of poor design from Zongshen. I also don't think you would see this design problem occur with either a Qingqi (QLink) or Lifan motorcycle. I'm hoping this particular problem is rare, and was resolved with later models of the Hawk motorcycle. Personally, I would be very disappointed if I received a motorcycle with this type of defective air box.
04-02-2016, 02:26 AM | #41 |
Now I see a report of a damaged O-ring on the intake manifold of a Hawk bike.
http://www.chinariders.net/showpost....2&postcount=59 I suggest every Hawk owner should examine the carburetor intake manifold for this problem. If the O-ring is not intact, you will draw dust into the cylinder, which will eventually damage the intake valve and its valve seat. In addition, the same fellow indicated both valves were tight in one of his Hawk motorcycles, with no clearance whatsoever. http://www.chinariders.net/showpost....8&postcount=62 Tight valves will quickly become burnt valves, resulting in engine damage. These kind of problems are the result of poor quality control at the factory, which can cause a lot of grief for inexperienced mechanics who don't thoroughly examine a new motorcycle.
04-02-2016, 02:37 AM | #42 | |
04-02-2016, 11:27 AM | #43 | |
soooo..... Finally, Hey WolF, before I forget, there is a guy on I think Ali express who sells a really nice reusable pod filter that comes w a ducted metal shroud to protect the filter from flying debris as well as to kill the intake howl (directs it downward. Very cheap and combined w the aluminum intake manifold, one pretty much solves the whole intake strength, efficiency, noise issue. All for less than 30 bucks total. Reusable really is a godsend when out running thru the boonies , and thanks again for the url on that valve cover /oil radiator setup. damn that think is nice.
04-02-2016, 01:32 PM | #44 | |
Thanks for the clarification. I accept your apology. I'm glad you enjoy your bike, and did not receive a defective air box. I am also glad you received excellent customer service from RPS. I certainly hope the defective air box reported by Wolftrax is a an isolated instance, and does not indicate potential problems for other prospective buyers.
04-02-2016, 11:28 PM | #45 | |
That said, I was going over some old threads last week in search of info and ran across one from "trevort" and he made a support for a pod filter for his Q XF200 CV carb that he was racing.
