04-23-2015, 11:50 AM | #3076 |
It is for me. My travel trailer / caravan had standard incandescent bulbs for interior lighting, and they were overheating the enclosed fixtures. A swap to LED bulbs solved that, but the light is a little blue for Mrs. Weldangrind's liking. I'm going to search for a brighter LED.
04-23-2015, 12:04 PM | #3077 | |
-------------------------------------------- Just found a nice short vid of Honley Rx3 out on a ride. |
04-23-2015, 12:09 PM | #3078 |
I bought some LEDs to replace the overhead recessed floods in my house - initially bought the daytime white and found them to be super harsh but super bright - have since bought "soft white" LEDs and they are much nicer and less harsh.
04-23-2015, 12:16 PM | #3079 | |
Usually, LEDs prevent flashing. LEDs use less electricity than incandescents and usually do not draw enough juice to make enough heat to activate the thermal device in a conventional (cheap) flasher. LED sellers made a LOT more money selling and installing resistors wired parallel to the LED lamps to cancel out the energy saving benefits of LEDs (they didn't tell you that, did they?) so the original flashers would get hot enough to flash. This is a sorry, complicated, expensive solution to a very simple problem. A better solution is to pull the flasher from the vehicle, walk into any auto parts store, hand the counterperson the flasher, and ask for an electronic version of the same flasher because your LEDs messed up the flash rate. The electronic flashers are not load sensitive and just about always work perfectly no matter what combination of bulbs you have. $12, 5 minute fix, without chopping up your OEM wires. If your bubble-baby turn signal out indicator is still causing a high flash rate, a single resistor in the wire between the flasher and electronic module that contains the indicator out sensor wizardry will cure the problem. A careful look at a schematic will reveal which wire needs the resistor. I'll leave the calculations of the necessary amperage capacity and resistance value up to you as the concept is too advanced for this medium of communication.
"Thou shall not Zong" is not a commandment. |
04-23-2015, 12:47 PM | #3080 | |
Cheers!
'20 TaoTao Hellcat 125 "grommet" '04 Yamaha TTR-125LE '00 Yamaha TTR-90 '07 Kinroad XT200GY Runmaster (sold) '07 KMD GY6 150cc ATV (sold) '07 Kangchao 250cc ATV Monster (sold) Baja Moto DB-30 "Doodlebugs"(x3) (sold) '06 Hi-Bird 200 parts bike (sold) |
04-23-2015, 01:44 PM | #3081 |
Hi Weld! I'm doing good, was out of the loop for a while but now I'm catching up. Lol
04-23-2015, 04:25 PM | #3082 |
They put out a little heat, but I don't think anything will melt. If anything melt's on my bike, I'll let everyone know.
Honda CB300R ABS |
04-23-2015, 04:27 PM | #3083 |
Thank you, Stew. It is great to hear from you again; we have missed you.
04-23-2015, 05:03 PM | #3084 |
Well, I do have a couple of H4 projector lamps without housings around the shop somewhere. If something melts, dremel it out of the way, and I'll hook you up with a source. One would be pretty easy to mount in place of whatever that extra light is.
04-23-2015, 06:01 PM | #3085 | |
First oil change: When?
04-23-2015, 07:42 PM | #3086 | |
Next ride will be speed limits up to 55mph in the loess bluffs running along the east bank of the Mississippi River, then a roundabout route home through the rolling hills of west Kentucky and Tennessee, ending with a 65mph run over the last few miles. I'll stop along the way for lunch and maybe a couple times to let the engine cool. Back home for fresh oil. Third and fourth break-in rides will be day long wanderings, speeds up to 65mph, among the hills of west Tennessee and Kentucky, as far east as Land Between The Lakes and perhaps as far south as Shiloh. Each ride will cover 400+ miles so several stops, a fresh filter and valve check after the third. The final break-in ride will be first light until dark and in the same areas, but will include some brief stints on 70mph parkways and interstates. Ride five should see about 1500 miles on the odometer, so will be followed by an oil and filter change, but Mobil 1 4T will be going in. I plan to have the forward illumination issue sorted before the 5th ride, which looks like it may be a SS1000, just because I haven't done one in a year and a half. Might do a BB1500 just for spits and tickles.
04-23-2015, 09:32 PM | #3087 |
new zong
yes spud,,i agree the front forks need something ,,i hope thicker oil helps!!just got mine assembled,,engine guard an luggage with the lugggage guards.i switched out the the top trunk for the larger J.c. whitney quick release one...On that note they dont build them like they used too.My brand new jc whitney trunk had a crappy flimsey mounting plate which it wouldnt stay latched too!! ,,so i got the old one (same size} out from my old zong and mounted it and it works and latches down down perfect and the mount plate it definately made better at the latch point.But of course ,I buy a new bike and now its freezing here in central PA Now to try and mount up the cree L.E.D. spots,i got of Ebay for $50,,maybe try an mount them engine guard,,,,,,,,,,,
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
04-23-2015, 10:27 PM | #3088 |
And in the red corner...........
Tonight is bike night in Glendale, AZ and I thought I'd introduce Phoenix to my RX-3.
George 2016 CanAm Spyder F3-L |
04-23-2015, 11:53 PM | #3089 |
You do know you will have to road trip to Yuma one of these weeks before it gets too hot...
04-24-2015, 01:54 AM | #3090 |
Were there any comments or questions from spectators?
