Old 03-21-2017, 12:44 PM   #16
zackattack91   zackattack91 is offline
The stator is good at charging the battery. I'm not worried about that too much. But 72 watts, divided by 12 volts. Should be 6 amps. So just in case, I'm going to you a relay and harness and get a little handlebar switch. And use the light bar only when I really need to.
2016 Coolster 3150-DX2
Old 03-21-2017, 03:47 PM   #17
Swampy   Swampy is offline
Swampy's Avatar
Originally Posted by goat67 View Post
If I was to do this I would not tie into the existing harness for the 12 volts. I would get the voltage in a separate harness with a relay. Just to be safe and not overload the existing wiring.
Do you have a wiring diagram I could look at it and then could see if you could use the existing switch to engage the relay.
Just read the posts below it sounds like you can use the hi beam wire the blue one to tie into the relay that is what I would do.
This is good advice for the lights you want to use. Keeps your stock switch and tap into the high beam (blue) wire for the relay.
1986 TT350, 2002 Grizzly 660, 2009 TR125 and two 2015 Kandi 150cc Quads.
