Old 08-09-2016, 10:38 PM   #16
Bruce's   Bruce's is offline
Good luck with that !
Old 08-09-2016, 11:13 PM   #17
nonone   nonone is offline
By searching "oko pe" and "oko pwk" as well as "oko (some identifying number like 32 for 32 mm)" you should find what you are looking for. Just make sure you don't buy a 2 stroke carb. You might want to consider KOSO as well.
The carb pete has pictured is a pwk.
Jets for keihin pwk will work with oko or koso pwk. Jets for keihin pe with work with oko or koso pe.
Here are some examples I don't know if they will work for you. I would measure the distance between the bolts and the intake before ordering anything.
http://www.ebay.com/itm/152149425573
http://www.ebay.com/itm/321983376312
http://www.ebay.com/itm/111956223756
http://www.ebay.com/itm/281788483294
http://www.ebay.com/itm/322220406323
http://www.ebay.com/itm/111956219507
Old 08-09-2016, 11:19 PM   #18
jerickw   jerickw is offline
Doh!
thanks so much for the links and info on searching i wanna saw its 44mm from the center of each bolt hole but ill have to check again i may be wrong and i think i need a 26 or 28mm carb the one i found of oko i noticed last second didnt have a choke and was for 2 strokes
Old 08-09-2016, 11:47 PM   #19
It can very difficult to figure out / find the right thing. I've had better luck on ebay because the pictures are always supplied by the seller even if's a stock pic (for ebay motors anyway). With amazon you sometimes get other sellers latching on to a listing created by someone else and it doesn't always match what you get.
If you want a little more response a bigger carb with bigger venturi may be something to consider the caveat is not too big.
