Old 04-29-2009, 10:47 AM   #1
Dragon   Dragon is offline
Bouncing after wheel balance
After I balanced the front wheel with the axle-on-jackstand technique, the front of my bike bounces at around 35 mph. Fortunately, there's no bouncing at higher speeds.
Chinabikeless
Old 04-29-2009, 11:25 AM   #2
Cal25   Cal25 is offline
Take a look at the bead of the tire all the way around the rim on both sides. I had a heck of a time getting the stock tire to seat it'self properly on the rim. Had to break the bead loose, apply soapy water, and re-inflate several times to get it to properly seat in the correct location.
Even though it might be balanced, the tire might be rolling like a wheel on Mr. Magoo's car
Old 04-29-2009, 12:00 PM   #3
forchetto   forchetto is offline
There's a line moulded all the way around the tyre about 5 mm from the rim. Check that this line is equidistant from the rim all the way around. If not, the usual procedure is to deflate the tyre until there's just a few pounds in it and bounce it on the floor, turning frequently until the bead sits properly.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 04-30-2009, 08:51 AM   #4
You're a genius, forchetto. Yep, the bead was not properly seated. I inflate and deflated about a dozen times, before the bead would sit properly. Soapy water helped, and so did prying. This tire is original, stock. So, I haven't touched it since day-1, 8000 miles ago. Apparently, I've been riding with this badly seated tire for that many miles without realizing it.
Chinabikeless
Old 04-30-2009, 09:53 AM   #5
Mine was that way also but I noticed it and got it right before riding. Glad you got it set.
Old 05-01-2009, 09:17 AM   #6
katoranger's Avatar
8000 miles on the front tire. Your doing good. Mine was badly cupped after about 4000. Very happy with my duro median replacement.
Allen
Old 05-01-2009, 10:01 AM   #7
Yep, 8000 miles on the front tire, and it still has some life left in it. The rear tire was recently changed to Kenda. The rear was dangerously worn out, when I changed it. 1500 of those miles were highway; rest were city miles. The compound on the stock tires are very hard, which was probably why it lasted so long.
Chinabikeless
