Old 05-16-2024, 06:05 PM   #1
newguy93   newguy93 is offline
Irate starter issue on hawk 250 please help
just bought a used hawk 250… but the electric start doesnt work( i have to kick start) when i press button it seems like it wants to but just doenst…. any idea what this fix is?
Old 05-16-2024, 06:13 PM   #2
Will it start ok with the kick starter but not the electric?
If so then I'd start by looking at the battery.
Will it hold charge?
What's the voltage without any load on it?
What's the voltage when trying to use the electric start?
Check Thumper's post here for battery issues
https://chinariders.net/showthread.php?t=34080
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 05-16-2024, 06:40 PM   #3
XLsior   XLsior is online now
XLsior's Avatar
low/dead battery most likely
Old 05-16-2024, 07:15 PM   #4
Easy way to rule out the battery would be to hook up a jumper pack. If you don't have one of those you can use jumper cables and connect to a car battery - just make sure the car is not running.
Old 05-16-2024, 07:29 PM   #5
Read this!!!
https://www.chinariders.net/showthread.php?t=34080
Old 05-16-2024, 08:20 PM   #6
Exactly why I linked that in my reply above
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 05-16-2024, 09:04 PM   #7
thanks for the reply yall…… i will read that link….. but the batter is about 12.2 from what i researched thats normal? seen some youtube videos where they mention a relay…. but mine doesnt just make a click sound… it sounds like it wants to turn over but just doesnt… just got the bike so i have a lot of questions lol
Old 05-16-2024, 09:36 PM   #8
Likely the battery has too much internal resistance. voltage will be normal, but the Amp output is down, which is why the starter isn't turning.
Could also be a weak connection somewhere. Check and clean all of the contact points between the battery and starter and the grounds.
As I said, if you hook up a jump pack or to a different battery it will probably start right up.
Old 05-16-2024, 10:10 PM   #9
thanks @megadan yea im going to try that…. i never been a mechani or anything lol but i could follow instuctions pretty good…. so if electric start works from a jump then its the battery?
Old 05-16-2024, 10:29 PM   #10
It's a strong indicator that it is the battery. Before trying that make sure to go over all of the connections on the cables and at least make sure they are tight. The battery is generally the number one issue as these little powersports batteries don't have the longest service lives and are very easy to discharge until flat.
Just make sure the battery you connect to is not in a running vehicle. Car charging systems are way too powerful for a small powersports battery. They have more than enough power on their own to jump a motorcycle.
hawk250, starter, technical
