Old 03-12-2024, 10:12 AM   #151
Zapkin   Zapkin is offline
Zapkin's Avatar
I have the cheaper one on several bikes. I can't tell any difference.
lesson learned for me. just didnt want to go cheap and then accidentally tear them. the hand sanitizer works great. and...it disinfects those hard to reach places at the end of your handlbars. hehhe
2022 Hawk 250
Old 03-12-2024, 01:49 PM   #152
Zapkin's Avatar
as she sits today
Protapers? and Grip Puppies and windshield installed.
2022 Hawk 250
Old 03-14-2024, 10:23 AM   #153
Zapkin's Avatar
Grin
raised windshield and put bike on lift. surprisingly the front wheel is just a tad out of true (maybe where some of the vibes annoying me is coming from) but rear is fine. checked remaining spokes. greased chain. felt it all around and feels okay for now. oh had to adjust rear break switch. i feel it will be okay for putting around until I get the new rim and then I will take it locally to have tire and tube replaced and wheels trued... for spring and additional savings. i know I share too much, but my family and friends are sick of hearing about the Hawk. hehehe.
ID:	31006   Click image for larger version
ID:	31007   Click image for larger version
2022 Hawk 250
Old 03-14-2024, 05:41 PM   #154
Do©Hawk   Do©Hawk is online now
Thumbs Up
Originally Posted by Zapkin View Post
I know I share too much, but my family and friends are sick of hearing about the Hawk. hehehe.
All good! That's why we're here.
I hated that crappy plastic brake light switch on my Hawk. I had to fuss with it before every ride and was never real sure my brake lights were working while I was on it. For under $10, you can replace it with a banjo bolt unit that mounts to the top of the rear master cylinder. The one I got was plug n play. The banjo bolt unit is metal, non adjustable(just works), and is tucked in behind the frame. The plastic one is in a vulnerable spot.
Keep it in mind if you ever have to replace the switch.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
Old 03-15-2024, 11:07 AM   #155
Zapkin's Avatar
Originally Posted by jeffrey View Post
Might want to check on a new front tire very soon to prevent said guts from spilling on the road.
I will be okay until I get the new rim. I did some research, I am not riding it offroad, I am missing only one spoke and I made sure the rest are not loose. I cannot find a single incident of a rim with one missing spoke just collapsing. In fact, if the design was so fragile that one lost spoke would be catastrophic, well, I doubt they'd be using spokes in the first place.
that being said, pray for me. i am a procrastinator and i have misplaced priorities. That rim is over 200 bucks plus I might as well get a new tube another 30 plus i might as well get a new tire too..another 70. Right now I can't afford to dump 300 at one time into the bike and since it is my only form of transportation (other than begging family) I will take the risk.
2022 Hawk 250
Old 03-15-2024, 04:09 PM   #156
Zapkin's Avatar
do you have a link? thx
2022 Hawk 250
Old 03-15-2024, 06:11 PM   #157
severely   severely is offline
Why not get a new front tire and tube and save up for the wheel? I'm with you one spoke won't stop the show, just pull the bad spoke when you put the tire on so it doesn't flop around. And be a nut about spoke tension. I'm seeing wheel assemblies for $150, free shipping; front tire for $54 and tube for $13 on ebay. Good luck.
Old 03-15-2024, 09:15 PM   #158
Zapkin's Avatar
It's the rear wheel that has a missing spoke. I put JB weld over the hole months ago and just kept riding. Does that front tire look that bad? jeez. Now I need two tires! ugh.
2022 Hawk 250
Old 03-15-2024, 10:26 PM   #159
I couldn't really tell from the pictures, but the front tire usually outlast the rear. On my TBR7, my front was still good, when the stock rear was needing replaced, so I just replaced the rear, with a new 50/50, because that bike came on 50/50 tires. The stock rear knobby on my Hawk had worn down to the point that the side of each of the center knobs, that contacts the road last, were worn down to the non treaded part of the tire, and the part of each center knobs that contacts the road first was still sticking up some. The front was showing the same pattern of wear on the center knobs, BUT the tire was probably only about what I would estimate to be half, or a little better worn out. I replaced both, because I went with a 50/50, but I probably could have ran the front knobby for a good while longer. I would say that if your rear is plumb wore out, then your front is probably still around 40 percentage, or better, but I don't know for sure. On dry paved roads, you probably don't need deep tread, but sometimes you can get caught in an unexpected rain, so while I would say your front tire should still have some usable life left in it, I would not let it get too bald in the center.
Old 03-16-2024, 07:13 AM   #160
Same for the rear. Maintenance costs are part of riding, if you can't afford tires maybe park it.
Old 03-16-2024, 09:10 AM   #161
buzz   buzz is offline
Wow if i knew that i would have given my old ones,only 3000 miles on the mine that wanted them could not find anyone! so into the burn pit. I bought my rear tire on ebay for $41.00 free shipping,not really what i wanted but the price i got it.Check on ebay for tires on auction,have bought a lot of good deals from them. Hope this helps.Buzz a TBR7 rider,with 8600 miles and still running strong,
Old 03-16-2024, 09:19 AM   #162
Zapkin's Avatar
yeah not gonna happen bro. but thanks for the advice.
2022 Hawk 250
Old 03-16-2024, 10:24 AM   #163
Zapkin's Avatar
Best deal I could find on Ebay
Look this:
2022 Hawk 250
Old 03-17-2024, 07:13 AM   #164
Hydraulic Brake Light Switch,... https://www.amazon.com/dp/B07DRF3ZRD...p_mob_ap_share
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 03-17-2024, 07:02 PM   #165
vividpixel   vividpixel is offline
vividpixel's Avatar
If you have not already corrected it, your mirrors look to be on backwards.
Templar X 250: 14t / 42t, Nibbi PE30
