12-24-2023, 01:29 PM | #1 |
templar x Engine Torque specifications
Does anyone know where I can find the engine Torque Specifications for my Templar X 6 speed?? I need the engine specs not the frame and wheel specs.
Cylinder Head, Valve Train, Cam shaft Sprocket, and all the Specs pertaining to the Engine and its internals. I have tried most sources on line with no help. PLEASE HELP ! |
12-24-2023, 02:30 PM | #2 |
K'ermiit's suggestion to use bolt specs might be all you can find for the ZS 172FMM, but I will keep looking... He posted it in the Templar Resource thread.
Here is another one https://www.boltdepot.com/fastener-i...ed-Torque.aspx There are more of these out there. I searched "bolt torque by bolt type" and got many resources to consult. I will be doing head work this Winter, so I will need these values. I think these specs are fine for new bolts, and these ZS 172 engines have standard metric bolts. After all of that engine work, I will buy new head/cylinder bolts. I may reuse many other less critical bolts. I have beam type (not clicker type) torque wrenches. I have a big one with ft/lbs and metric, and I have a small one with inch pounds for smaller bolts. I will use an average value from various charts if i can't find a ZS172 specific set of specs.
12-24-2023, 06:28 PM | #3 |
engine Torque specifications
Thanks Thumper, I have the 300cc kit and want to install it but don't want to do it until I have the engine Torque Specs.
