12-05-2023, 08:21 PM | #1 |
Kill Switch Bashan Storm 250
So TLDR my Bashan storm does not have a kill switch. It instead is a hazard light......could I rewire my hazards to be the kill switch?
Side note: the alarm system and keyless start bs was removed already so thats not in the bike |
12-11-2023, 07:28 AM | #3 | |
Assuming the wire colors are the same on these bikes.
2020 Bashan Brozz Recon 250 |
12-12-2023, 04:36 PM | #4 |
Thanks that helps a ton.
12-12-2023, 05:06 PM | #5 |
Check this post. https://www.chinariders.net/showpost...36&postcount=9
12-12-2023, 06:41 PM | #6 |
Thanks all! Ended up following goat67's way of doing it and got it to work pretty easily. Completely cut the orange wire off and just spliuced the blue to the green and the grey to the black and white. Very easy honestly and happy I didn't need to pay anything to do it.
1984 Honda Magna V30 Custom bobber, rigid shocks 2014 Bashan Storm 250 Pod filter, Denso 4099, Rotella T4 15w-40 2021 Vitacci Bullet 85/33 jets, 5g roller weights, 80cc big bore |
