Old 07-12-2023, 05:59 PM   #1
CorvZ061   CorvZ061 is offline
TaoTao 125 no spark. Halp!!!!
Back to this POS TaoTao 125. It now hasn’t run in about a month, no spark. It quit while driving. Coil tested bad, no continuity from either pole to the wire end. Replaced coil, no change. Checked for volts at the plugs for the coil, no voltage while engine spinning over, swapped CDI with a known good one, as well as Voltage regulator with a known good one. Tested stator and found bad. Remove cover and stator smelled burnt. Replaced stator/pickup, no change. Bypassed all kill switches, no change.
I’m about ready to just throw this damn thing away because all components with ignition system test good, it should spark but doesn’t.
What am I missing here?
Old 07-12-2023, 06:34 PM   #2
Originally Posted by jeffrey View Post
Have you replaced the spark plug,sometimes they just quit.
Yessir, has a Ducar plug in it.
Old 07-13-2023, 07:51 AM   #3
cheesy   cheesy is offline
cheesy's Avatar
Sounds like a short to ground, which would explain the cooked stator. All that’s left is the wire harness.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 07-15-2023, 11:21 AM   #4
spark
the first thing to check....normally .... is the black and white kill wire at the cdi... put test light end on positive battery post... witj key OM.. touch that wire.... if light is on the test light .. THEN SOMETHING IS KILLING the spark... remove that wire from plug... and see if you have spark... EASIEST thing to do first... and then go from there... you have many problems as you stated... about the stator... so this is NORMALLY.. when things are godd.. report back
ABIBABA ATV ETC
Old 07-16-2023, 05:13 PM   #5
Test light did not come on. Depinned that wire anyway to test, still no spark.
