Old 03-18-2023, 01:34 PM   #1231
That’s rad my dude
Old 03-18-2023, 01:37 PM   #1232
Even after sealing the manifold with RTV, i still need to hold choke/rpm up for about a minute before she'll idle on her own.. i think this is the most prevalent issue (feature) with the Templar's
I didn’t realize many were having this issue?
Old 03-18-2023, 04:13 PM   #1233
Zapkin   Zapkin is offline
Zapkin's Avatar
Zooker that thing looks great!
2022 Hawk 250
Old 03-18-2023, 04:18 PM   #1234
Hammer13k   Hammer13k is offline
Looks great!
Old 03-18-2023, 06:03 PM   #1235
Zooker89's Avatar
That’s rad my dude
Originally Posted by Hammer13k View Post
Looks great!
Thanks guys! I hope I can get it all buttoned up in the next two weeks. It is looking like spring might actually come soon.
Old 03-19-2023, 03:29 PM   #1236
Zooker89's Avatar
Got some more done today
I got some more graphics applied this morning. The rear fender was a tough one...
I also realized I need to shorten the license plate bracket...
ID:	28823   Click image for larger version
Old 03-21-2023, 11:35 PM   #1237
WeebleWobble   WeebleWobble is offline
WeebleWobble's Avatar
Figured while I had my carb out I'd take the intake horn with me to the auto parts store and see if they could match up a thermostat housing gasket to it. They found a very close match...
Gasket is made by Fel-Pro. Autozone part number is 35368. Applications on packaging are for:
Ford V6 1993-2002
Nissan V6 1986-2004
Templar X 250
Yamaha XSR900
Kawasaki Brute Force 750
Yamaha TT-R 50
Old 03-22-2023, 11:51 AM   #1238
Attachment 28848
Attachment 28849
Attachment 28850
Ford V6 1993-2002
Nissan V6 1986-2004
Real good info! Thanks!
Old 03-22-2023, 08:16 PM   #1239
Twowheeler   Twowheeler is offline
Those tires look a little different to me, than my new M's tires. Mine are the stock China ones, which do not read DOT. I need to find good DOT replacements, before my inspection. I thought there was mention of Dunlop D606 tires, on a thread. Any advice would be greatly appreciated.
Old 03-23-2023, 07:13 AM   #1240
Huck369   Huck369 is offline
Huck369's Avatar
The Shinko 244 series is a decent low cost Dual Sport tire
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 03-24-2023, 10:04 AM   #1241
GypsyR   GypsyR is offline
GypsyR's Avatar
Rode mine to work this morning. First time REALLY out on the highway. BRRRR knobby tires.
I see what you guys mean about the gearing. Still breaking in so I didn't wind it out but I could use just a tad more gear I think. I'm holding off on that until I get it muddy. I like really low speed tractor power for the piddly bit of off road stuff I do. We'll see. Sprockets can be had cheap enough I might just experiment.
Who was it that found a rear wheel? I kind of like the idea of swapping the knobby for a dual sport wheel already mounted.
Old 03-24-2023, 10:22 AM   #1242
And here we come right back to the issue of "dual sport"!!!
On one hand- If you opt for tall gearing then you can get to 70-75mph no problem, but 1st gear isn't low enough and 2nd is almost useless off road!
On the other hand- Stick with the OEM gearing, or even switch to a 50-53T rear sprocket for better off road operation, and you just have to avoid the highway (county roads still "OK").
Swapping out the rear wheel is a viable option, but LOTS of work! Doable if you must go 75mph.
These bikes are so cheap, I have two of them to solve this problem...
The 5 speed has 14T front (up from 13T), 49T rear and I might restore the 13T front sprocket.
The 6 speed has 13T front and a 39T rear.
Personally, I just drive slower. The off road useability is just too important for me. I can still get to Home Depot, grocery store, liquor store without any worry about getting a ticket on the 5 speed coming back from the trails!! I even have a horn
Old 03-24-2023, 10:25 AM   #1243
Agreed. its a wasted effort to try to make the bike a do-all bike as no matter how you gear for top-end, it'll always be uncomfortable.. for true road worthiness, you need a bike that can easily break triple digits if you want to cruise comfortable on the highway and have enough power to get you out of trouble (just dont have too much to get yourself into trouble).. I was ok with the 13/42 for awhile but then wanted some of that oomph back in first gear and the 14/49 is a sweet spot for me, great off-road and then enough torque to carry 6th gear
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 03-24-2023, 02:11 PM   #1244
GypsyR's Avatar
I was talking about having a second rear wheel. Set up with a dual sport tire and a road sprocket. This is just me. I don't spontaneously dart off into the woods to hit a trail or two. When I actually go offroad it means with grandkids. Meaning trailered bikes, air tank, gas can, cooler, lunch, helmets, first aid kit, etc. A certain amount of prep work is required anyway, so I have no issue with doing a wheel swap to the "fun" tire/gearing. Wife says I turn wrenches in my sleep.
Most of this bike's duty will be running around. Yes, I know a TBR7 or a Hawk probably would have better suited. The Templar just called to me. At some point I expect to hang it off the back of my RV when we go certain places. We won't be off roading and as much as I like the knobby tire it won't suit. I'd much rather swap a wheel than a tire. Front tire I'm not worried about...though now that I think of it....
Old 03-24-2023, 03:55 PM   #1245
That's the best way to do it and getting a second set of wheels from powersportsmax is not very costly. I did an email inquiry a short while back and so long as you stick with the default wheels that come with their bikes they'll sell you some as they have a default policy of not supporting putting any wheels of a different size on any bikes they sell, for safety or something, so no supermoto thoughts for street use and 18/21 for off road use. If you want supermoto wheels you will have to buy them elsewhere.
If you also leave your front sprocket alone then you can also have two different rears set up, one with the shorter gearing for off road and one with the taller gearing for street use.
