Old 02-22-2023, 06:23 PM   #1
vader125   vader125 is offline
Boom Vader BD125-10 lower engine mount bolt
Boom Vader 125 lower engine mount bolt keeps breaking I've changed it out twice already, the stock one broke, then I bought a grade 8.8 bolt and it broke in less than a week, then I bought a grade 10.9 bolt and it broke in a couple weeks, I do have another grade 10.9 bolt, the thing is I would like to get a stronger bolt maybe a grade 12.9 bolt, What bolt would work the best? Thanks
2021 Boom Vader BD125-10
Old 02-23-2023, 07:36 AM   #2
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Grade 8, not metric 8.8, but grade 8 standard
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 02-23-2023, 07:58 AM   #3
Thanks, that’s what I was thinking, do you know if this one would work?
Dorman - Pik-a-Nut Cap Screw-Hex Head-Grade 8- 5/16-18 x 5 In.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old 02-23-2023, 01:53 PM   #4
CheapThrills   CheapThrills is offline
Broke mine too, even though I ensured the chain wasn't too tight.
Replaced it with better quality bolts: https://mymotorcycleblog.com/boom-va...olts-replaced/
Then figured it was time to upgrade the bolt sizes by drilling out the engine mount holes:
https://mymotorcycleblog.com/boom-va...olts-upgraded/
Going with larger bolts made the bike feel more solid to me, with less vibrations.
Just what I did, and liked it.
- My 2 Bikes:
TaoTao TBR7
Boom Vader Gen 2 (BD125-10)
Testing a YouTube Channel
Old 02-23-2023, 07:59 PM   #5
Nice thanks for that update how to put even bigger bolts.. for now I used the 5/16-18 grade 8 bolt and so far so good we’ll see…
Old 02-24-2023, 05:45 AM   #6
4T_Goblin's Avatar
You do not need to drill anything. You want as much metal to screw to as possible. Those are mount holes are already small enough. Just get the grade 8 5/16" about 4.5 to 5 inches long and some washers until you add a third mount
2022 Lifan KPX 250
Old 02-24-2023, 02:12 PM   #7
Already bought that bolt and put it on with some thread lock, it looks stronger for sure, what third engine mount do you recommend and is it really necessary?
Old 02-26-2023, 03:06 PM   #8
Deckard_Cain   Deckard_Cain is offline
For the WHAT: You aren't going to find one commercially made, it's going to need to be done by you or someone else. Typically they are welded to the swingarm tube of the frame, then bolted to either 2 or all 4 lower engine mount bosses that are already there.
I'm working on making one for my 190 swapped Vader this spring, but I plan on mine being removable and bolting to the frame instead- especially since I'm going 212cc with 4v head and the extra power and torque will be nasty.
For the WHY/Is it necessary: One could successfully argue that it should have been there from the factory. Same story with the actual Honda Grom... for those, you can buy the extra lower mount but they don't exactly fit onto the clones.
So basically, I'd say yes, it is necessary. Even on a bone stock engine, it'll take all of the vibrations out and smooth it over nicely, make the bike feel more solid when the engine is running. On any kind of modded engine, 141cc kit, or better... absolutely in my experience and opinion,
Old 02-26-2023, 09:17 PM   #9
4T_Goblin's Avatar
There are third motor mounts available but as Deckard explained they will have to milled out to fit the clone, or you will need to make your own.
I do not have a third mount on mine yet
2022 Lifan KPX 250
Old 02-27-2023, 05:45 AM   #10
Thanks for the break down, it seems like it will make it better for sure, I’ll probably do it once I get around to it since it needs to be welded and not a direct bolt on. For now hopefully this grade 8 bolt holds up.
Old 02-27-2023, 05:49 AM   #11
I’ll have to wait to do that one since it isn’t a direct bolt on, seems like it would make a noticeable difference.
