02-22-2023, 11:04 PM | #1 |
KPX 250 valve adjustment
Hi everyone from Florida, so I just passed 100 miles on the KPX and so far everything has been good except the rear tire was rubbing on the exhaust pipe so I just tried a 5/8" spacer between the top bracket and the pipe so I will see if that works. Has anyone had this problem? Also, when should I check/adjust the valves? Is there a certain milage you go by or do you tell by the way the bike runs? Thanks
____________________________________________ 2022 kpx250 2007 Suzuki dr650se(project bike) 2002 Hyosung prima 50 1979 Kawasaki KZ650sr 1972 Kawasaki F7 175 1971 Kawasaki G5 100 |
02-23-2023, 07:58 AM | #2 |
No issue with my rear tire rubbing but there have been a hand full of owners that did.
I did my first valve adjustment at 500 miles. My exhaust valve was tight and needed adjustment.
02-24-2023, 11:13 AM | #3 |
Thank you for your response Jerry, these 4 strokes are new to me. Also is the tool you used to adjust the valves available on amazon or is it a motorcycle shop thing?
02-24-2023, 11:30 AM | #4 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-24-2023 at 02:27 PM. |
