Old 01-29-2023, 01:27 PM   #466
IdahoRider   IdahoRider is offline
Originally Posted by joefj1200 View Post
Notes on a Shinko 705 4.10-18 rear tire mounted on a KPX 250:
~0.8" smaller diameter than stock, so lowers the rear of the bike ~0.4".
~0.4" narrower than stock.
Weighs a significant ~2.2 lbs. less.
6000 RPM in 6th gear, ~60 MPH with stock tire
6000 RPM in 6th gear with, ~54 MPH with Shinko 705
Cost $83.16 delivered. I mounted and balanced it myself. Took 1.25 oz. to balance.
Feels pretty good in the first test ride...
More to come...
I'll be curious to hear how well they work, the tread pattern is so similar to stock.
2022 Lifan KPX 250
Old 01-29-2023, 02:12 PM   #467
kyle   kyle is offline
More to come...
Great info, mind if I share on kpx250com?
Old 01-29-2023, 03:01 PM   #468
joefj1200   joefj1200 is offline
joefj1200's Avatar
I don't mind at all.
2012 V-Strom 650 Adventure
Old 01-29-2023, 03:03 PM   #469
joefj1200's Avatar
Added 20mm bar risers, primarily to make room to slide the forks up in the triples...
I ordered these from Amazon, $16.88 delivered. They fit great:
https://www.amazon.com/dp/B07TWFH33Y?ref=ppx_yo2ov_dt_b_product_details&th=1
Old 01-29-2023, 07:32 PM   #470
joefj1200's Avatar
Quick street ride with the new Shinko 705 4.10-18 rear, with the front forks slid up in the triples ~0.400":
The differences are subtle but noticeable. Some small positive changes, minimal cost, and no downsides, at least for how I'll be using the bike.
What was I trying to accomplish? To lower the seat height slightly to make it more friendly for shorter, less experienced riders, without major cost, and fully reversible. What did I accomplish?
* Lowered the seat height and center of mass almost 1/2". My wife claims she can't tell the difference, but I can tell she can handle it a little better at a stop.
* reduced the rear tire weight by over 2lbs. The bike should accelerate incrementally faster, and less unsprung weight improves compliance over bumps.
* raised the bars relative to the seat by 20mm. Should be more comfortable for me when standing on the pegs.
* Effectively lowered the gearing for better or worse.
Cost me a total of $100.04, and my time to install the tire and bar risers.
Potential downsides, at least in theory:
* I lost 1/2" of ground clearance. I can afford that. I ride 90% street, 10% gravel roads.
* I lost some small amount of cornering clearance. If I start dragging pegs I'll consider that problem when I get to it. Then it might be time for stiffer springs.
* Rear tire is slightly narrower. Anywhere I was going to go on the stock tire, I can go on this one...
Riding the bike on the street it feels ever so slightly lower, but also maybe more "planted". It maybe feels a little less clumsy at slow speeds and going into slow corners. It feels great going into 50-60 MPH corners. I think it will feel better for gravel roads, and the kind of light trail riding I'll do on the bike. It's definitely feels better for street riding.
The main thing I notice is the lower gearing as a result of the smaller diameter rear wheel. I have a 14-tooth sprocket I'll install this week and see where that gets me. I can pick up a slightly smaller rear sprocket if I'm then geared too tall...
So at this point, I'm totally happy with the results. YMMV...
Attached photo of my bike with the new rear tire and lowered front.
Old 02-01-2023, 04:21 PM   #471
joefj1200's Avatar
More to come...
Swapped in the 14 tooth front sprocket and went for a quick ride. I was surprised to find it's still geared slightly shorter than stock.
6000 RPM in 6th gear, ~60 MPH with stock tire and front sprocket
6000 RPM in 6th gear, ~54 MPH with Shinko 705 and front sprocket
6000 RPM in 6th gear, ~58 MPH with Shinko 705 and 14-tooth rear sprocket.
Old 02-22-2023, 01:18 PM   #472
I just sent them an email asking about it. Just waiting on a replay.
Did you ever get a response from Venom? (When you inquired about replacement air filters)
2022 Lifan KPX 250
Old 02-22-2023, 01:23 PM   #473
Oh i guess i didn't post it. lol You can request for the air filters from Vemon or contact American Lifan direct. contact@americanlifan.com
American Lifan does have them in stock.
2020 Kawasaki Vulcan S
Old 02-22-2023, 02:03 PM   #474
Thanks!
2022 Lifan KPX 250
Old 03-01-2023, 03:41 PM   #475
Venom motorsports doesn't have the filters listed on there site yet. You can call them to order though.
Venom just quoted me $49.99 + Free shipping. Pretty spendy for a China bike. May look into making a foam filter by removing the paper from the stock filter and replacing it with foam when the time comes. Mine still looks good after 2800 miles.
2022 Lifan KPX 250
Old 03-01-2023, 03:49 PM   #476
TominMO   TominMO is offline
You can also extend the life of a paper filter by vacuuming it with the crevice attachment to get between the pleats. Did that to my car's engine and cabin air filters and they look almost new.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 03-01-2023, 04:18 PM   #477
You can order direct from American Lifan for about half that price.
Old 03-14-2023, 01:18 PM   #478
Zapkin   Zapkin is offline
Zapkin's Avatar
I am curious if anyone has compared the EFI components on the KPX to those of the XPect. I was wondering if they are similar.
Old 03-26-2023, 07:32 PM   #479
Jay93   Jay93 is offline
Hey guys! So due to a questionable $35 lever set I now need a new clutch cable. Felt a bit of a grinding in my lever and discovered about three quarters of the braided steel clutch cable had sheared clean through, so fun! Does anyone know how to disconnect the clutch cable from the transmission end? I’ve been looking at it and I’m afraid to get access I’ll need to remove the exhaust. Any input from anyone is greatly appreciated!! 5700mi on my kpx so far and running smooth as butter!
Old 03-27-2023, 10:44 AM   #480
Yeah, it's pretty tight quarters. More than likely you will have to remove the header pipe.
