10-01-2022, 08:07 AM | #1 |
New to mini moto and site
Hello everyone, just got a 2022 Icebear Fuerza last weekend.
I’ve looked over the bike a bit and already fixed some issues: loose clutch lever adjustment nuts, loose throttle cable, wiring behind headlight hanging down by triple tree, chain adjusters not set evenly. Those issues have been fixed. I put fresh gas in, changed the oil and checked brake fluid Things I plan on doing: 16t front sprocket Here are my questions/what should I do (reliability): How do you drain and service the GL-3 gear oil What bolts should I replace, engine mounts What bolts should I torque What bolts should I thread lock Can you change the jets in the stock carb Suggestion on pod filter after air box delete Best bolt on exhaust, no modification Any idea on CDI box |
