Old 05-03-2022, 03:37 PM   #1
ChondaRyder221   ChondaRyder221 is offline
Hawk 250 speed cable issues
What's going on everyone. Lately I had to reroute my speedo cable do to the cable getting wrapped around my horn, now my cable is damage and I would like to replace it what are my options, I have not purchased the digital cluster at this time not really sure if I will either. Thanks
Old 05-03-2022, 11:51 PM   #2
Ol,fart   Ol,fart is offline
Ol,fart's Avatar
pm me. but I'm really happy with the Zanella cluster and recommend it.
2021 RPS Hawk "IKEA" (Came in a box with no instructions)
110 main jet 1washer,2.5 sprockets and the cat fell off( with a little help)
1984 Honda V65 Magna "Daddy's Little Monster"
To whoever stole my anti-depressants.
I Hope Your Happy !
Old 05-04-2022, 08:29 AM   #3
Ditch the stock cluster and go digital. It will be more accurate and the tach is nice to have.
2020 Kawasaki Vulcan S
Old 05-15-2022, 12:10 PM   #4
Countrytour   Countrytour is offline
My stock cable made it 2001 miles before the cable started to go and made the speedo bounce. Shame I had just confirmed it was only 2mph off at 60. Bought the Zanella, love the added tach and digital speed. Have the TBR7, set for a 17" wheel, only off by 1 mph.
Old 05-22-2022, 09:58 AM   #5
Crazyrigged   Crazyrigged is offline
How was the fitment? I plan on buying one for my project but didn’t wanna waste the money if there would be complications mounting it.
Old 05-23-2022, 08:29 AM   #6
Badluck   Badluck is offline
The zanella mounts exactly the same. It also uses the same connectors. There's an unused plug near the battery box that the dash uses for gear indication.
The only wiring I had to do was splice in the tach signal wire outside the connector. I did it last year and I think I soldered it, but you could use one of the snap together splice connectors. That went a little beyond the instructions, but it's better than stuffing the pin in the back of the connector and taping it like the instructions say.
Old 05-27-2022, 07:47 PM   #7
Had to change a couple of wires around because cluster is made for hawk not tbr7, just took the pins out of the connector and swapped them around. I cut and butt connected the old gear selector harness to the new gear selector harness to keep the stock connection at the steering neck. Tach wire I was able to attach at an empty connector pin at the steering neck. Fitment in place of old speedo is as if it were factory fitment.
