03-27-2022, 06:07 PM | #1 |
Another Hawk 250 jet thread. HELP!
I'm at 300ft elevation running a 115 main and honestly haven't noted the VM26 clones pilot size. I'm using the stock exhaust minus the CAT and running a pod foam filter. Only problem is a slightly rich at idle, which a smaller jet may fix. I've ordered what I believe to be the correct pilot assortment to remedy that. What puzzles me is the needles affect on idle. I moved the main jets needle clip down 2 notches to see what would happen at WOT and the bike would barely idle with the idle screw in almost all the way. The plunger was installed correctly also. I was under the impression that the needle height didn't drastically change anything about the pilot circuit. I have moved the clip around and recreated this issue everytime i put the clip any lower than half way. Anyone out there who can school me on why this happens?
03-27-2022, 06:15 PM | #2 |
I had a similar issue with the vm26. I started with needle I step below center mark and I found that I had the most annoying hesitation between idle and 1/8th throttle. I moved the needle to center and voila the issue was resolved.. so the needle had an impact at slightest of throttle position off idle. I recommend you keep at middle.
03-27-2022, 07:18 PM | #3 |
First of all. You need a better understanding of what jet affects what throttle position. The needle is going to have zero effect on WOT. 3/4 to wide open is 95% main jet. A 115 main with a decatted stock exhaust might actually be a tad big. The 115 works well with the aftermarket system, which does flow better than the stock system, even with the cat removed.
The needle mainly affects 1/4 to 3/4 with slight crossover past either end. The pilot jet has the strongest influence up to 1/4, and almost entirely off idle to 1/8th. A lean idle would be caused by your mixture screw being turned in. That screw adjusts fuel. Turning it out = more fuel. In = less. Also, a bigger jet numer means richer, not smaller. If it does use the mikuni pilot and main jets, I would look at a 25 pilot to start, mixture starting at 1 1/2 turns out from seated, and a 112.5 main. Needle in the 3rd notch. Start by getting your idle mixture dialed in with rhe engine at operating temp. Then, if you notice a slight hesitation at up to 1/8th steady throttle the pilot may still be lean, go to a 27.5 pilot. Then readjust the idle mixture. Once you have all that sorted then you can move on to the main.
03-27-2022, 08:00 PM | #4 |
Its running rich at idle even with the mixture screw all the way in....gas smell and slight black/Grey smoke. . I'm going to put the clip back in the middle, actually see what pilot came in it and install a leaner pilot I guess. It runs out great with the 115 and the clip in the middle....just that annoying idle that doesn't change with the mixture screw at all. Appreciate the feedback guys.
I said LEAN idle in my original post. Sorry, it's a rich idle I'm dealing with |
03-27-2022, 08:59 PM | #5 | |
03-27-2022, 09:47 PM | #6 |
Will do. Thanks man
03-28-2022, 10:34 AM | #7 |
I get the technical around the needle jet and pilot jet, but, can say from experience, that i tried everything with the stock pilot, adjusting a/f all over the place, and the only thing that helped was putting the needle clip back to center, so im thinking id does have an influence off idle up to maybe 1/4, enough to annoy the heck out of me during rides
03-28-2022, 02:01 PM | #8 | |
There is a reason I said basically everything I said, and stated the order in which to do those things in. I also always make sure the needle starts in the center and do my pilot and main jets first. They are the easiest to dial in thanks to their strong influence on either end of the throttle sweep, and the main jets influence on the needle and needle jet across the rest of the throttle range.
04-11-2022, 04:34 PM | #9 |
I was having so much trouble getting the jetting and Idle mixture right. I pulled the carb so many times to end up feeling absolutely dumb...so..... If you buy an extended fuel/air mixture screw... Don't use the spring that came with it. My screw was not seating correctly and was staying completely open/rich no matter the position.
I reinstalled the longer screw but this time used the orig. spring that came in the fake Mikuni and run a 20 pilot and 15 main jet for now. The jet needle clip is in the middle position...3rd notch down I believe. The bike runs great and idles perfectly now. I think I will probably just leave it alone. Until I get bored again |
