Old 10-27-2021, 08:06 PM   #1
weiser23   weiser23 is offline
Left engine cover crank bolt access screw
After smelling oil at every stop i looked down and noticed the left side crank bolt access bolt
Is gone, I know I have checked it recently but it must have vibrated a off , wasn’t sure what was going to happen I’d had a 40 Mile ride home but made it ( but the question is where can I get one in a hurry what is the proper name for this and the is there a Chinese MacGyver solution to what I could use till I can get a new one
Old 10-27-2021, 08:53 PM   #2
TominMO   TominMO is offline
Originally Posted by weiser23 View Post
.....is there a Chinese MacGyver solution to what I could use till I can get a new one
Gorilla tape. After you get the bolt access cover and remove the tape, use WD-40 to remove any glue left on the case.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 10-28-2021, 06:45 PM   #3
Stator Cover Crank Case Plug Cap Is what I need don’t know if any Honda models should work which I found some on line, I will try the tape until I can find the part I tried a few Chinese motorcycle dealer and get no response
Old 10-28-2021, 07:12 PM   #4
What bike is this on?
Old 10-28-2021, 07:17 PM   #5
Wow I can’t believe I didn’t put that in 2020 hawk 250
Old 10-28-2021, 07:57 PM   #6
dirtbkr188's Avatar
What is the ID of the hole where the plug cap goes?
Old 10-28-2021, 08:04 PM   #7
Check with TXpowersports or Orionpowersports as they both carry and sell parts for the Hawk.
Old 10-28-2021, 08:57 PM   #8
If your sitting on bike it’s the left side where you turn the engine over to set top dead center
Txpowersports is one that never responded, I saw some Honda cap on eBay, but wasn’t sure if they would work
Old 10-28-2021, 09:35 PM   #9
dirtbkr188's Avatar
I was looking for the inner diameter of of the hole, in mm, I stumbled across one earlier today with an outer diameter of 28.3mm, measured at the threads. I know the overall diameter is slightly bigger, and may be match to a Honda one shown HERE. Part #15 is 30mm wide overall, and part #19 (o-ring) is 27mm
Old 10-29-2021, 08:19 AM   #10
I'm pretty sure these are the correct parts because that's the same as what's on my Ghost which is a clone of the CRF230F engine.
Old 10-29-2021, 09:19 AM   #11
Unfortunately it has it’s unavailable
Old 10-29-2021, 09:58 AM   #12
dirtbkr188's Avatar
Possibly this one will work for you? Might be worth a try...
Old 10-29-2021, 06:27 PM   #13
Thanks I ordered one I hope it works I have I gorilla taped for now seems to be working
Old 11-01-2021, 09:12 PM   #14
Thanks the part work
