08-07-2021, 02:46 PM | #1 |
what type of bike is this and where can i get parts?
whats up guys i believe i have a vader or something close to a grom with an extended frame, and i need rear wheel bearings and damper set. i went to the local shops and they said they have to order them. gave them honda grom 2014-2018. any all help is greatly appreciated. i even have the vin but dont know where to go with that. attaching pics .ok i cant attach pics or drop and drag anyone know where i can send the pics so everyone can view and comment>?
08-07-2021, 02:50 PM | #2 |
08-08-2021, 06:10 AM | #4 |
When you take out the old bearings there should be a code stamped somewhere on the bearing. Usually it's cheaper to go to a bearing store to get replacements than to get them through a stealership.
2004 Longjia Grido 50 scooter 1999 Cagiva Mito 125 Evo, Yamaha XV125 engine, Ducati SS fairings, getting turboed 1993 Yamaha GTS 1000 Ex:Bashan BS200-S7 `07 Streetfighter-quad |
08-08-2021, 12:04 PM | #5 |
Get them on amazon or Ebay
Wheel Bearings- All Balls Racing front 22-51684 rear 22-51600 Rear Hub(Cush drive) Dampers- Honda 06410-KWB-600 Looks like a tao tao hellcat to me based on the engine.
2020 Boom Vader Gen 2 2019 CSC TT250 2021 Kayo Fox 70 |
08-08-2021, 02:37 PM | #6 |
Thanx alot for the info
Name sounds mean lol imma look that up
08-09-2021, 09:29 PM | #7 | |
I would contact Pete at www.kronikracing.com as he used to carry Icebear products and either has parts and advice, or can steer you where to get them.
08-12-2021, 09:15 PM | #8 |
Wow def look like the iceberg. Handlebar setup and head light different but expected withthe year difference.
But for the part list given prior all good thanx alot on that. Now im running into small issue mounting the wheel. The hub/sprocket assembly doesnt sit flush iguess cause the new bushings any thoughts? Btw added new axle bolt and nut too. The gap is enough for me not to get the wheel on with caliper setup. |
08-13-2021, 06:05 PM | #9 |
Fuerza has a different engine with a N-1-2-3-4 shift pattern. That is a tao engine. Could be a fuerza swing arm though. It also looks like the bodywork was painted at one time. Fuerza and hellcat both run the gen 1 grom style bodywork.
08-15-2021, 04:20 AM | #10 |
wel heres what im talking bout whats happening.
i need a washer/spacer that centers the outer bearing .the one i seen are just spacers. i need it to fit in the bearing anyone know what im talking bout.
08-15-2021, 01:22 PM | #11 |
https://www.partzilla.com/catalog/ho...-ac/rear-wheel
I believe you are talking about #4 or #5 on the linked page.
