05-27-2008, 12:11 PM | #1 |
Suspension Front
I was riding on rough pavement this weekend, and noticed the front suspension doesn't seem to absorb the shock very well. The front is too stiff, in my opinion. I don't have much experience with dirt bike, but my Honda road bike is a lot smoother over the same rough pavement. Is there anything I can do to the front forks?
Chinabikeless |
05-27-2008, 12:15 PM | #2 |
Yeah, my Roketa is the same way. The forks seem soft anough on ALL terrain except quick little studder bumps. On the small, quick bumps it is like the suspension can't move quick enough to obsorb it. Only option is to run a lighter fluid, or pull the forks and revalve them.
05-27-2008, 01:56 PM | #3 |
Swapped my original fork oil for 5W and believe the forks are smoother and more responsive.
05-27-2008, 02:09 PM | #4 |
Is there a how-to article somewhere?
Chinabikeless |
05-27-2008, 04:29 PM | #5 |
It is easiest to remove the fork legs and invert them (with caps off and springs removed) to drain the old oil. Some may suggest removing the screw from the bottom of the forks but there is a degree of risk in such an approach. The screws hold the dampening rods in place and sometimes retightening becomes difficult. Measure oil removed and replace with same amount.
