Old 07-14-2021, 08:43 PM   #1
gwowzer   gwowzer is offline
Clutch Service Life
On average, at how many miles does the clutch need replaced? If you've had to do it, please describe the way the bike was used before it needed replacing.
Old 07-14-2021, 10:26 PM   #2
franque   franque is offline
Pretty much never with these, depending on how it was used (loading, slipping, style of riding), if used gently, until you run out of adjustment on a new cable, I could easily imagine 40-50k miles.
Old 07-15-2021, 05:48 PM   #3
Oldenslow   Oldenslow is offline
Of course, a crappy clutch is always a possibility, but assuming it's decent to begin with how long a clutch lasts depends greatly on the operator. Right out of college my sister and I bought identical Toyotas. She had hers 3 years and in that time needed three new clutches; I had mine 12 years and sold it with the original, still-working-just-fine clutch in it.
Old 07-15-2021, 09:03 PM   #4
Boatguy   Boatguy is offline
Boatguy's Avatar
In my imagination, I figure people who gear up their bike by changing the front sprocket to enable higher top speed are going to go through more clutches.
2020 Lifan x-pect
Old 07-16-2021, 08:11 AM   #5
Nah! 5 year old Hawk with well over 8000 miles and still stock clutch. Normal driving will not kill the clutch. Tying to pop wheelies and dogging it every time you take off with even stock gearing will wear it out.
2020 Kawasaki Vulcan S
Old 07-16-2021, 12:24 PM   #6
Mudflap   Mudflap is offline
The splines where the clutch attaches to the transmission input shaft were getting slightly loose at around 40,000 miles on my Lifan. Nothing that was going to break, just noise. Replaced the whole clutch, $38.
