05-26-2008, 07:15 PM | #1 |
Horn on Komoto 250cc doesn't work
The horn on my bike doesn't work. I checked the wiring from the handlebar hosing to behind the headlight. I also checked to make sure the wiring to the horn was okay. I will probably have to take off the gas tank to see if the wiring is good. I will have to use a volt meter to see where the disconnect is. Anyone have any problems with their horn?
05-26-2008, 07:57 PM | #2 |
Common problem with some of the Hi Birds. Try tweaking the adjustment screw located on the back of the horn. Usually just a slight shift in position will have desired results.
05-26-2008, 11:21 PM | #3 |
I loosened the adjustment screw and no beep. Do you think it's the wiring? I need to get it working otherwise, I can't take my motorcycle license test. I only have a permit now.
05-26-2008, 11:25 PM | #4 | |
05-27-2008, 08:43 AM | #5 |
I checked my horn and had no voltage to the horn. Traced back to a bundled connector behind the headlight. Power on one side of the connector but not on the other. Bypassed the connector with a splice and then had voltage at the horn bur it still would not work. loosened the adjustment screw and it started working. Been fine ever since.
