Old 05-25-2021, 07:37 PM   #1
Jeshmont   Jeshmont is offline
Easiest way to access Ghost carb?
Seems like at first look those auxiliary lights are in the way but I didn't investigate too far as I tackled other tasks. Whats the best way to get access to it?
Also any info on removing the seat would be helpful as I couldn't figure it out. Thanks!
Old 05-26-2021, 08:24 AM   #2
To remove those side covers you will have to remove two nuts from the back side of the cover that hold the lights on then you will have access to two bolts that hold the cover on. It was a pain but doable.
In order to remove the seat you will have to remove the bolts located under the rear fender. It took me a little while to figure it out. Check out my Saddle bag install video and it will show where they are located. Link to my YouTube channel below.
2020 Kawasaki Vulcan S
