01-30-2021, 10:43 AM | #1 |
New to me Hawk EFI: electrical problems, or?
Just picked up a 2019 Hawk EFI yesterday with some weird stuff going on.
Rode the bike home 22 miles yesterday. Can't say for certain, but it feels like it is running as it should. So, no performance problems me thinks. Here is the history of the bike that I was told:
Other things I found on the bike:
I am left asking myself a question: is there a global electrical problem on the bike connected with all these problems? Either a short or a regulator issue? I have replaced the running light in the front with some LEDs i had laying around - not sure how long they will last if the voltage is all over the place. I don't want to replace the dash if it is just going to burn up like the previous. Any thoughts? |
01-30-2021, 10:52 PM | #2 |
Sound like it just wasn't taken very good care of. Minor maitence issues and a cluster although I would check the cables coming from the cluster for damage, sounds like they could of got pinched.
01-31-2021, 02:22 PM | #3 |
I would check the voltage output being produced with the engine running. If the regulator takes a vacation, it can allow excessive voltage to burn out bulbs as quickly as you can replace them. It can also overcharge the battery, causing it to boil off its electrolyte. Any charging voltage above 14-15 should be checked closely. I think normal would be in the mid-14's, approaching 15.
tom
vertical and above ground - my daily goal |
01-31-2021, 04:08 PM | #4 |
I had the regulator/rectifier fail on a Polaris atv and after replacing the headlight bulbs 2 times I discovered that was the problem.
