Old 07-16-2020, 03:18 PM   #1
Virtual_Rider   Virtual_Rider is offline
First time Taotao owner. I have some questions
Hey there. I picked up a TForce for the kiddo and she loves it! I have a couple questions about it though:
How do I tell what the engine displacement is? I see info showing both 110cc and 124cc. Is there something I can look at to see what's actually installed?
I have some pretty pronounced popping in the rear end. It still happens with the chain off the sprocket so it's not that. Any suggestions where to look next?
I want to install a magnetic drain plug but I can't find the size/thread pitch. I picked one up that's 12mmx1.5 but it's too big. Any inputs?
I'm sure I'll have more. Thanks in advance.
Old 07-16-2020, 03:22 PM   #2
Ok....just double checked and I actually ordered a 14mmx1.5 . That probably answers that question.
Old 07-16-2020, 04:19 PM   #3
Bruces   Bruces is offline
What does the engine look like ?there are numbers on them but with no idea what it looks like we can’t be any help .
Old 07-16-2020, 04:41 PM   #4
ZiptieJonez   ZiptieJonez is offline
Looking at the bottom left side of the case, you're looking for an FMI or FMH with a few numbers before that. Also, you can check on the cylinder jug. It sometimes will say "107cc" or "124cc" or something along those lines. VIN plates will also list the displacement of the engine as well.
Old 07-16-2020, 04:42 PM   #5
Does this image help?
Also regarding the popping, I lifted the brake caliper off and it still popped. I broke the right rear axle nuts loose (the big one with the jam nut) just to investigate. As soon as they were a bit loose the popping stoped. I torqued them down again and the popping did not return. So it's fixed but it's still a mystery what the cause was.
Old 07-16-2020, 04:43 PM   #6
Thank you! I'll take a look.
Old 07-16-2020, 04:50 PM   #7
Big Bird   Big Bird is offline
Big Bird's Avatar
110cc
2020 Boom Vader Gen 2
2019 CSC TT250
2021 Kayo Fox 70
Old 07-16-2020, 04:52 PM   #8
Thank you! That's not what I was told it was but that's no big deal for my purpose.
Old 07-16-2020, 06:04 PM   #9
crazythunder1968   crazythunder1968 is offline
Originally Posted by Big Bird View Post
110cc
how did you determine that from the pic he sent? enlighten us.
Old 07-16-2020, 07:02 PM   #10
Big Bird's Avatar
The H in the engine code designates 110cc engine class. "I" is 125cc. The 52 is the bore size, the 1 is the amount of cylinders,M means motorcycle,TZ is the manufacturer etc.
2019 CSC TT250
2021 Kayo Fox 70
Old 07-16-2020, 08:42 PM   #11
Big Bird FTW
Old 07-17-2020, 07:49 AM   #12
so i have a genuine 125cc. thats good to know. thanks for the info.
Old 07-17-2020, 06:04 PM   #13
Your info conflicts with this tag on the front of the frame. Any idea why?
Old 07-17-2020, 06:23 PM   #14
Mudflap   Mudflap is offline
The engine numbers are not always correct. My Taotao ATA250D engine number was 171FMM which would be 71mm bore but I measured it at 63mm.
Old 07-17-2020, 06:36 PM   #15
Big Bird's Avatar
Because you are dealing with china. Honesty is not a virtue in their culture. You really don't know what you have until you crack it open and measure it. Every single chinese vehicle I have owned has been misrepresented on engine size. Pocket bikes, pitbikes, motorized bicycle engines. Every one of them.
2019 CSC TT250
2021 Kayo Fox 70
