05-01-2020, 09:39 AM | #1 |
Apollo Sportrax 125 oil leak - what brand engine?
My kids have an Apollo Sportrax 125cc atv which leaks oil from the sight glass seal, clutch cover, and the two big bolts on the cylinder head. It’s not leaking a ton of oil but seems like it would be a few easy fixes with the right gaskets and seals. From searching online it appears its a Zongshen engine but I cannot find any markings on the engine which would identify it. Is it a Zongshen engine? And can I purchase any gasket kit for a 125cc engine and it will fit?
I found some that appear to fit at https://mytrailbuddystore.com/zongsh...gasketset.aspx Thanks for the help! |
05-01-2020, 12:38 PM | #3 |
152FMI and below it between two stars is 17048675
05-01-2020, 03:32 PM | #4 |
Any ideas? With google searches I’m seeing both zongshen and loncin
05-03-2020, 10:33 AM | #5 |
So it would be leaking at the stator cover. Still trying to figure out engine manufacturer.
05-03-2020, 04:23 PM | #7 |
I just picked up a New 2017 Sportrax, any idea where to get a rear sprocket? The inner diameter is 47mm. I can only find ones with 52mm but then it doesn't ride on the hub, only the bolts.
2017 Apollo Sportrax 125 1996 Redcat MPX-50 (SOLD) 1986 Honda TRX200SX 1979 H-D FLH1200 |
05-03-2020, 04:45 PM | #8 |
Member humanbeing on here knows the manufacturers ,but I am pretty sure it is not a zongshen because they have a z in the numbers .
05-05-2020, 09:45 AM | #9 |
I sent a message to humanbeing and am hoping for a reply.
05-05-2020, 09:46 AM | #10 |
Why are you looking at replacing it?
05-05-2020, 10:06 AM | #11 |
These 52.4mm cames in 2 varitey:
https://item.taobao.com/item.htm?id=608475382218 Zongshen, Lifan https://item.taobao.com/item.htm?id=521606865936 Jialing, Loncin Sight glass, case cover oil leaks can fixed easily using RTV seal maker IF u know how to applies it (don't clog the oil paths !!!) .
05-05-2020, 11:51 PM | #12 |
Thank you for the response humanbeing, I will be trying the rtv method. Any idea who the engine manufacturer is?
05-06-2020, 02:58 PM | #13 |
It has a hard time going up inclines from a stop, gotta get a running start. Mine came stock with 12 front and 37 rear sprockets. I just found BMI Karts has sprockets to fit. I ordered a 45T. My 10yr old doesn't need that much top end anyway. They were out of stock till I called. Then they corrected the website so I could order one. They are 48mm I guess. Kinda odd size. I bought the 52mm that is listed as fitting Apollo on some sites, but after I tore everything off I found it was too big.
2017 Apollo Sportrax 125 1996 Redcat MPX-50 (SOLD) 1986 Honda TRX200SX 1979 H-D FLH1200 Last edited by Wolfairious; 05-07-2020 at 04:29 PM. |
05-06-2020, 10:03 PM | #14 |
I’ll keep that in mind for the future. My 7 and 6 year old don’t need it to go fast yet but I have noticed it’s pretty slow off the line. Please keep the forum updated with any mods you do in the future!
