Old 05-25-2019, 07:01 AM   #1
brugotti   brugotti is offline
Plastics
Does anybody know if the body parts/plastics from the bros 160 or the XR150l
fit on the hawk 250?
Old 05-25-2019, 08:53 AM   #2
NzBrakelathes's Avatar
Different
I have some plastics new red or black
What you looking for?
Old 05-25-2019, 03:49 PM   #3
Don't need i was just asking because they look similar and i might need some in the future
Thanks
Old 05-28-2019, 10:41 AM   #4
Duggo   Duggo is offline
I broke the front plastic hook on the gas tank plastic. Its not bad yet, but I'm sure the wiggle will get on my nerves eventually.
You have 2018 Storm 250 plastic?
Old 05-28-2019, 02:55 PM   #5
I done that the first time I removed the tank. Forgot to remove the bolt from the bracket. JB Plastic weld works great. It's been over 2 and a half years and still holding up.
2020 Kawasaki Vulcan S
Old 05-28-2019, 04:21 PM   #6
krawl   krawl is offline
If it is ABS plastic you could use a dab of acetone which will melt the plastic and fuse it together once it dries. Be careful though, you don't want to get the acetone on any plastic part that you don't want marred up. You might test it on the back of one of your panels first to see if it will soften the outer layer of plastic, if it does work it will fuse better than any other plastic bonding solution out there.
Old 05-28-2019, 09:44 PM   #7
Tashka   Tashka is offline
its Polypropelene plastic. I've mended mine extremely well with a soldering iron and melting it together...
Old 05-29-2019, 11:21 AM   #8
Harbor Freight carries a cheap plastic welder (basically a soldering iron with a flat tip) and rods for PP, ABS and PVC.
Old 06-14-2019, 03:10 PM   #9
Well shit, I think I lost the little broken piece. Maybe I can make a bracket.
Old 06-14-2019, 03:43 PM   #10
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Try Versimold. its moldable silicone. Youtube how it works. you'll end the new plastic idea.
https://www.amazon.com/Versimold-VM0.../dp/B00NQ11AQI
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 06-17-2019, 11:48 AM   #11
jimwildman   jimwildman is offline
jimwildman's Avatar
i broke that tab off almost right away.
3m 2way tape that to the gas tank,, make use its the grey removeable stuff not the white foam stuff.. works well and comes off when you need it to.
500cc Hawk Project http://www.chinariders.net/showthrea...372#post281372
