05-23-2019, 02:28 PM | #856 |
The owners manual doesn't even give directions on how to check the oil level. Huh?
Friends are the people who rush in to help when adversity strikes. I am a Friend of Bill Wilson. Are you? Retired and living the dream in Yuma, AZ. |
05-23-2019, 03:31 PM | #857 | |
"What you want is for the engine to have the oil level even with the upper mark on the viewport when the motorcycle is in the vertical position (straight up and down; not on the sidestand). The viewport is located on the right side of the engine. Here’s what it should look like…"
05-23-2019, 07:22 PM | #858 | |
Could gas be getting to the oil somehow? Thereby raising the oil level in the crankcase? I think I will just drop the oil and put in some fresh and leave the filter alone until the 500 mile make and change the filter and the oil then. Then I will have something to watch. Think of it this way.... my knowledge of this bike can only go up from this point!
05-23-2019, 08:52 PM | #859 | |
05-24-2019, 12:50 PM | #860 |
Larry, your bike sat around for a long time so you absolutely do want to change the oil right away. Do you have filters? It probably doesn't need one, except that the oil is old in age not miles, and could have built up contaminants. It surely has the original oil fill in it and hasn't even had the break-in oil change. Your plan to change both again at 500 seems reasonable.
As far as level, lean it over on the side stand; does the level appear to go down? If not, then it's probably significantly overfilled. I'll put pics below of mine on the side stand (no oil visible) and center stand (oil at half). If there's any chance you'll be in Phoenix and need a filter, I'd be happy to give you one. Otherwise ordering a supply from NZ is the best way to go. He'll sell you a kit with a bunch of filters and some spare o-rings and sealing washers at a great price. You're also welcome to bring the bike for a little time working on it, I have a full shop and have gone through a lot of the bike a few times now. On oil choices, I've been using Rotella T6 which is cheap for a synthetic and it works great, seems to be staying clean. |
05-24-2019, 08:32 PM | #861 |
https://www.ebay.com/itm/30316519476...84.m1555.l2649
That is the filter link - need the small black filters or O rings etc just PM I can do etc and just accept Paypal n post to you |
05-25-2019, 08:23 PM | #862 |
I changed the oil to quakerstate motorcycle oil and left the filter in the bike. I now have 450 miles on the bike. I will put a few hundred more on the bike while I am waiting for my filters that I ordered from CSC.
I also had to order 2 key blanks as my bike came with one key. I have been riding it on some gravel roads and a few trails, but mostly on the pavement. I like this bike. I think it will be a keeper. I need to fashion a sheep skin cover for this seat. Or add a jell pad. Ouch.
06-12-2019, 10:14 AM | #864 |
I must have that sticker.
06-12-2019, 03:43 PM | #865 |
Here you go...
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 In "what did you do today," I'm installing a high-power USB adapter after work, that just arrived from Amazon. The OEM optional one, as everyone knows, doesn't have enough power to even keep up with a modern phone running music, let alone GPS too. |
06-12-2019, 10:34 PM | #866 |
But golly gee Wally.... Won't the lettering be way too small to read if it has to fit on the end of the round?
06-13-2019, 09:59 AM | #867 | |
06-13-2019, 01:59 PM | #868 |
DAMN! I just realized I should have gotten two. I have a "new" CBR1100XX arriving tomorrow.
06-14-2019, 01:37 PM | #869 |
larryinseattle "Could gas be getting to the oil somehow? Thereby raising the oil level in the crankcase? I think I will just drop the oil and put in some fresh and leave the filter alone until the 500 mile make and change the filter and the oil then."
When changing oil, put in 1.7 quarts. The oil in the window raises and lowers so don't go by that necessarily. The RX3 has 2 oil pumps and the oil level in the window all depends on how long it has ran. So read the tutorial and I believe it says something about starting it for so long, shutting it off and then putting the bike upright to check level in window. It's been a few years since I read it as mines a 2015. As far as gas ,antifreeze getting into the oil to raise the level, this was a big concern back in 2015 when the bike was new and we didn't understand why the oil level would go up and down and assumed they had problems with gas getting into oil. NOPE On my bike I put in the 1.7 quarts with filter change and never hardly check it until next oil change. rj
Live Zong, and Prosper |
