Old 03-31-2019, 10:02 PM   #1
Pathog3n   Pathog3n is offline
Unknown Pilot jet
Can anyone recognize this jet? I pulled image from online but it's the same one on my Lifan KP mini. It came from a Sheng wey carb. Standard Main jets fit but can't find these pilot jets anywhere online.
Old 04-01-2019, 08:20 AM   #2
Ahhh! The mystery jet. Good luck finding those. Same pilot jet that comes on the stock Hawk carb. What size did it come with? If it is a 40 you should be okay as far as the pilot jet. Try adjusting the idle mixture screw. It will be hidden under a plastic or brass cap.
2020 Kawasaki Vulcan S
Old 04-01-2019, 10:12 PM   #3
Hi Jerry and thanks for the reply! I was thinking I may just replace with a 26mm nibbi or mikuni. What are your thoughts on that? Any real performance boosts over these chinese carbs? Thanks.. and yes it was a 40 pilot and 108 main. But the main I was able to swap.. went to a 120 since I changed the can on it and it's still cold here in Mn. 40-50ish.
Old 04-04-2019, 01:35 AM   #4
NzBrakelathes's Avatar
You can find a #45 on Clevland cyclewerk site,
https://clevelandspeedshop.com/colle...c-full-jet-kit
or simply drill it out
I have searched in China and I can get 1000 made sure but not going to bother as drilling the jet out is good enough.
I have this is my bike a 223cc OHC - I drilled it out to 0.45mm and correctly adj air screw - problem solved.
Here's my listing should it help you
https://www.ebay.com/itm/303077495104
Old 05-12-2019, 09:54 AM   #5
Actually I managed to find these
Old 05-31-2019, 09:36 AM   #6
Check my eBay store and there’s a kit with these jets
