03-04-2019, 08:31 PM | #1 |
Spark plug cable
My plug doesn’t sit well on my spark plug good anymore It’s really loose does someone know what spark plug cable to replace with? Has anyone else had this issue?
03-04-2019, 08:38 PM | #2 |
Can you adjust the crimp with pliers "carefully" through the rubber boot. So it grasps the tip better? Might need a flashlight to look down into the boot to see it.
03-04-2019, 11:17 PM | #4 |
Or something fancy and more expensive like this?
03-05-2019, 12:26 AM | #5 |
I thought of doing this just scared and don’t want to crush it with out a replacement on hand. Guess I’ll stop by my shop and see if they have a replaceable boot first before I try it in the parking lot that way if it crushes I can replace it. Thanks guys
03-05-2019, 02:24 AM | #6 |
Are the HT leads replaceable in the coil ?.. or just the cap... ..
03-05-2019, 07:25 AM | #7 |
Get rid of the plug wire and just do like I did and install a coil on plug. Link to that mod is in my signature.
