12-19-2018, 06:47 AM | #16 |
[QUOTE=
Will be throwing a properly jetted mikuni, and the 17/45 gears on my other hawk probably next week and then some kenda or vee rubber 80/20 dual sport tires to see how much the road manners improve.[/QUOTE] did you ever get the touring tires. I'm very curious about weather or not its worth it for my hawk |
12-19-2018, 12:23 PM | #17 | |
With my last Hawk, the road manners were vastly improved when I went from the stock knobbies to a set of Shinko 705's, which are very road oriented. If you put a set of strictly road tires on, it will be even better still. There is at least one member here that has done this, and he only had good things to say. The downside is that you lose a lot of off road capability, so if you don't plan on going off pavement with your bike, then it is a good way to go. If you want to retain some mild off road capability, a set of 80/20 tires like the Shinko 705 is a great option.
12-19-2018, 01:08 PM | #18 |
I just got some new Shinko 705s and I love them. What sucks is right before I got them in the mail I noticed my chain slipping and saw my 43 tooth rear sprocket was almost gone. So I put the 45 I have on was almost new but still loooked new and that lasted maybe 3 days. Only thing I can think of is the O-Ring chain going bad so yesterday I went back to 17/50 and stock chain. This morning was my first time riding to work and I was able to get it up to about 71 engines screaming though at about 9000rpm. Off freeway straight road I can get it to 63 easy. Looks like the O-Ring chain was my problem I’m guessing, gonna leave the 17/50 on it for a couple more days and if my rear sprocket stays good I’m gonna throw on my last sprocket I got a 39 and save the 50 for backup. Haven’t taken the 705s off-road yet but on road they’re great. Gotta thank megadan again for the box of extra sprockets and chains they’ve come in handy.
12-19-2018, 02:25 PM | #19 | |
Glad they came in handy. Most of it was used, some of it new. Strange to hear that the chain went bad already, but you might have put it through more severe use than I did and it already had about 3000 miles on it.
12-19-2018, 03:37 PM | #20 |
Yeah definitely riding 50 miles round trip to work and back mostly freeway at about 70. I had bought Shinko 244 last December and completely wore out the rear tire back in October. Didn’t last me a year so I threw on stock rear knobbie with from Shinko 244 both had plenty tread still and both wore completely out a couple weeks ago. So that’s why I went with more street tires. Way smoother on freeway now
12-19-2018, 04:43 PM | #21 |
Thanks for the info guys I think I will go with some 80/20s. Did anyone get a top speed gain with the street tires?
12-19-2018, 05:23 PM | #22 |
I would like to say yes, but I don't have any definitive data. In theory a more aggressive tread like the stock tires will have a higher rolling resistance due to the deflection and deformation of the tread blocks. That said, if there was any gain in top speed, it was at best maybe 1mph or so, which is arguably no real change at all. What you will get is a much smoother ride at higher speeds and a much more stable and comfortable experience. A lot less vibration through the bike as well.
12-19-2018, 09:47 PM | #23 | |
12-20-2018, 12:11 AM | #24 |
Agree with megadan I can’t really tell yet since I’ve gotten the new tires due to both my sprockets and chain wearing out but at high speeds the 705s are 10X better way less vibration a lot smoother, enjoyable ride. I wouldn’t think I could get any faster than my top speed at 76 but a lot more, I wanna say funner but auto spells not letting me so I doubt that’s right. Couldn’t recommend them anymore if you do more riding on pavement than dirt. I’ll give an update once I hit the dirt trails and mud cause I got trails all over the back of my neighborhood but have not tested the new tires out there yet. Heck I’ll take vid of both freeway and trails soon for everyone to see. It’s about time I learn how to start posting vids
12-20-2018, 08:57 AM | #25 |
I'm a newbie when it comes to the Hawk and I'm considering switching to the 17/45 sprockets. But I weigh 250lbs and do plan on off roading it some so I don't want my first gear too high for putting around in the woods and climbing small hills. Does anyone have any input on this?
12-20-2018, 09:08 AM | #26 | |
12-20-2018, 11:45 AM | #27 |
Just for reference: All the japanese 250cc dual sports are 14T sprocket. They have better stroke an bore to handle better gear ratios though..
12-20-2018, 11:48 AM | #28 | |
As Jerry said, if you find it too tall for off road, a quick front sprocket swap works really well. A 16/45 is equivalent to a 17/48 (2.81 ratio), and I found that ratio to be a really good compromise between off and on road. A 15/45 will give you the same basic factory ratio as a TT250, which comes with a 17 front and 50 rear. So if you really wanted to you could simply start with a 45 rear sprocket and see if you like it, then spring for a different front depending on how it feels to you
12-20-2018, 11:51 AM | #29 |
All Japanese dual sports tend to come with a 520 chain as well, making a 14 tooth front sprocket larger than a 17 tooth 428 chain sprocket. Making your comparison a bit apples to oranges. My bike has a 13t 520 front, mostly because it's effective size is just slightly smaller than a 17t 428 sprocket (but bigger than a 16) and a 14t 520 is too big to work with the Hawk sprocket cover.
12-21-2018, 01:31 PM | #30 |
Thanks Jerry and Megadan. Yes I am a big fella, 6'2" 250lbs size 13 shoe and have to special order my hats and gloves lol. I also hit a Subaru wagon head on at high speed on a Yamaha Seca and lost my left leg when I was 18. But I can ride anything and operate any piece of machinery. Dan has me thinking I should switch to the 520 setup right from the gitgo, all my other bikes run a 520. Be interested to know what a 16/45 ratio be on the bigger chain. Still gonna play with the 428 to figure out my ratio though, dont want it buzzy at 55 but also wanna hit the numerous trails here in southeast Ohio. Also are there not any welders in the group? Because of my big feet and artificial leg I'm gonna need wider pegs, but I'm just gonna cut the stock ones in half and use thin flat bar to make them 1.5" longer.
