11-15-2018, 11:49 AM | #1 |
Good power pack/jump starter
When camping, either tenting or even in my motorhome, I like to use one of those power/jump packs to charge everything. Also I keep one in the Jeep just in case, and will be carrying one on the RX3. I had one that was failing, so it was time to shop for a new one. The one I had was from Anker, and while I love their USB products, this was my second one that failed in a rather short time. So I won't buy their power packs any more.
Man, are the specs on many of these just ridiculous lies... I ended up buying one that claimed really high capacity, and when it arrived, I could see by the size that it was nowhere near that. Normal Chinese "spec" lies? No, this was a new level. I put a power datalogger on it, and measured it out at 1/12th (one twelfth) the rated capacity. Sheesh. Also it wouldn't reliably output 2.1 amps to fast charge a tablet, sometimes it would just stop. Back it went. Tried another, and similar thing. Also the jump portion of it felt like it was made from tin foil and christmas light wires. Awful, tiny. So I picked up this after careful research: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 I like it a lot. The power tester says it is at least close to specs (you'll never get full power out of a Lipo, as doing so would damage it). The connections are quality. It is waterproof and rugged. It has USB-C to charge directly to our laptops, micro-USB, and two USB-A ports. So totally universal. It also can be charged from the USB-C and micro ports, so you can use normal laptop and device chargers to charge it. I'll grab a second one to keep on the RX3 at all times too. |
11-15-2018, 03:09 PM | #2 |
I agree that these are great to have on rides, especially overnight rides away from civilization. The one I have is a few years old and a little bulky. I'd like to find a good one that will fit under the rear seat so it can charge when I ride during the day and then use it in camp at the end of the day. Also, without a kickstart I feel much better with the extra battery capacity.
This one looks great, I may take some measurements later today and see if it will fit under the rear seat. |
11-15-2018, 04:08 PM | #3 |
I've had a few different ones and I think the NOCO gb70 is the best but it is a bigger jumppak. This allstart boostmax 560 is an older model but paired with an Astro Pneumatic 7790 inflator, bailed me out of a flat on gsxr earlier. I didn't think it'd have enough oomph but it aired up the tire easily!
BD125-15 |
11-15-2018, 07:23 PM | #4 | |
https://www.amazon.com/gp/product/B0...L1NQPR7O&psc=1 It appears to be almost identical to what you have, with slightly lower (more accurate/honest?) listed power specifications. Still more than sufficient for the RX3 or any other motorcycle. Definitely handy to have. Safer for giving jump starts too, since I don't have to worry about damaging my vehicle's electrical system if the dead vehicle has a problem. I've had one battery blow up on me during a jump, about 20 years ago; not looking for a repeat of that ever. |
11-16-2018, 07:41 AM | #6 |
It's a common known fact that all electronics run on smoke. Once the smoke comes out, it will stop working.
11-16-2018, 09:36 AM | #7 |
I don’t really know what happened ,it was only a few months old ,I plugged it in to charge ,and it blew the cover off ,with the battery swelling to probably around double it’s size .
The 2000 amp Noco has been a real good unit ,I have had it two winters going on it’s third with no issues or magic smoke .I would think the 1000 amp model would be more than most people would need ,especially if you don’t live in the cold like me . |
11-16-2018, 12:34 PM | #8 | |
Also, I'll try fitment under the seat a little later, can't right now. |
11-16-2018, 12:35 PM | #9 | |
11-16-2018, 01:07 PM | #10 |
Bruces = winning with that gb70. I've used mine 'as' the battery on a volkswagon, 929rr, gs500, other bikes and of course jumped cars, charged phones and stuff. It's a great jumppak.
BD125-15 |
11-16-2018, 01:20 PM | #11 |
Useful tip: Most of these packs use a standard RC hobby battery connector for the 12v output. So I made a simple adapter to get 12v out of it, because the jump starter leads will NOT do that. I already had the connectors and clips laying around.
And yes, it fits fine under the seat. Just hold it against the seat itself, and set it all down to align it. You could probably figure out how to align it and then mark the location on the bike. |
11-17-2018, 12:01 AM | #12 |
Sweet! Happy to hear it fits. I ran 10AWG leads from the battery to under the rear seat with SAE plugs. You can get a short 10AWG EC5 to SAE cable to connect the jump pack to the 10AWG SAE battery leads for starting. This way I can trickle and jump with only popping off the rear seat. Since this unit will fit under the seat, my plan is to run a separate 12v accessory line to rear seat compartment and use a 3amp usb to charge. The seller states the unit takes about 4.5 hours to fully charge on a 3A usb c. So should be no problem to charge during a days ride.
11-17-2018, 11:26 AM | #13 |
You should never plug the jump start connector to the bike directly though. Not sure if you were saying you would do that, but sounded like it? It needs to go through the jump start leads which protect both the vehicle and the jump pack. They're not just leads; they have a control circuit in the connector. And yeah, it took around 5 hours to fully charge from my MacBook's charger.
11-17-2018, 06:55 PM | #14 | |
