Old 09-20-2018, 04:36 PM   #1
Whisky   Whisky is offline
Whisky's Avatar
New carb installed but..
It idles around 3000rpm I can take the idle screw completely out and still ides at 3000. The plunger is in correctly and there is plenty of slack in the cable. I put a 115 jet in on the advice of someone on here. No vacuum leaks that I can think off. Any ideas would be appreciated. I did a search already.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 04:44 PM   #2
cbrfxr67   cbrfxr67 is offline
cbrfxr67's Avatar
Choke on? You didn't say so gotta ask
BD125-15
Old 09-20-2018, 04:46 PM   #3
Chinabike   Chinabike is offline
choke only to start, then off till bike idles.
You might want to try smaller main jets
Old 09-20-2018, 04:47 PM   #4
Whisky's Avatar
nope I look inside end where air filter goes and slide will not go all the way down I don't see any obstructions anywhere
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 04:48 PM   #5
Whisky's Avatar
what size 110--105?
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 04:52 PM   #6
Did you adjust the idle mixture screw?
2020 Kawasaki Vulcan S
Old 09-20-2018, 05:01 PM   #7
Whisky's Avatar
yes seated and out 1.5 turns
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 05:02 PM   #8
cbrfxr67's Avatar
I'd open it up and make sure the cable is set right through the top. Maybe it's hung up somehow and not letting the slide go down. Keep fiddling with it, you'll get it.
BD125-15
Old 09-20-2018, 05:03 PM   #9
Whisky's Avatar
air fuel screw=seated and 1.5 turns out idle screw does nothing I can turn idle higher but not lower
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 05:06 PM   #10
Whisky's Avatar
cable is in correctly. I took cable completely off plunger and plunger still does not go down all the way. I do have carb off currently
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 05:19 PM   #11
Whisky's Avatar
I changed to a 110 jet and idle is still 3k and when I give it some throttle it makes a sucking sound and dies.. going to put the 115 back in as it didn't have the throttle issue
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 05:20 PM   #12
Whisky's Avatar
Probably will just put stock one back on for now
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 09-20-2018, 05:29 PM   #13
Do you have the slide in the right groove? You might have it reversed. The long narrow groove slides on the pin and the wide groove goes towards the idle screw.
Old 09-20-2018, 05:52 PM   #14
SilverBullet51   SilverBullet51 is offline
Its going to idle high if the slide isn't going all the way down, it doesn't matter what jet you use if the slide doesn't seat. Is the needle sliding freely into the main jet?
Old 09-20-2018, 06:48 PM   #15
Whisky's Avatar
I had everything correct, as I said before I took the cable off the slide and the slide still doesn't go all the way down. It was an ebay Mikuni carb, could have been a lemon. I will spend more $ and get one straight from Mikuni this time. I put the stock one back on and it runs fine so that will have to due for now. Thanks for all the input though.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
