Old 06-22-2018, 03:46 PM   #46
xxtra_strength   xxtra_strength is offline
This happen to me 2 days ago on my Vemon X20 Boom BD125-10 around 270 miles.
Old 06-22-2018, 04:17 PM   #47
siikmonkee   siikmonkee is offline
siikmonkee's Avatar
I feel bad for not reading absolutely everything and seeing if this was addressed...I actually had this happen twice on my lil monster. I replaced the 8mm with a longer 5/16" - I actually think that I put half an inch longer on both the top and the rear, then put lock washers. That stopped the mount from vibrating on the threads and breaking them all over again.
I haven't put threadlocker on mine just yet, but in over 1000 miles, I haven't actually needed it. I've checked the tightness multiple times, but it has stuck right in place. Not to say that you shouldn't, just that I haven't needed it in my experience.
I did this same procedure on my Hellcat before going anywhere, since this is apparently a common issue - I'm about 600 miles on the hellcat with the same experience after the replacement.
EDIT: I just read a few posts before this, which echoes my observations about the length of the bolt. So take this post as a 'I second that' post.
Last edited by siikmonkee; 06-22-2018 at 04:18 PM. Reason: Just read a few posts prior
Old 06-28-2018, 04:28 PM   #48
It's an old trick and there might not be enough space to do this but if there is , you can always use a little bit longer bolt and use a lockwasher, run the the first nut tight on it, and then add a second nut and tighten it against the first one. It won't ever come loose again that way .In any case yeah everything I have read about caring for or modding these Grom clones no matter which one it is , has said to repl all the engine mount bolts with non " chinesium" ones right away ,and also the swing arm bolt as well altho that doesnt seem to fail quite as bad as the engine mount ones do.
Old 07-20-2018, 03:07 PM   #49
Samurai   Samurai is offline
Engine bolt broke off too for my venom x20. I went to Home Depot I got one their bolt close to our chinesium one. It seem to be holding for 400 mile so far.
Old 09-17-2018, 02:33 AM   #50
JoeRivers   JoeRivers is offline
I have a Boom bd-125. First stock bolt broke ~400 miles. I added a second bolt that I was too short so the threads ended up at the interface of the engine and the mount. That broke around 100 miles later. Ive replaced it with a longer bolt this time so well see how it goes.
Old 09-17-2018, 06:48 PM   #51
Whisky   Whisky is offline
Whisky's Avatar
On my BD 125-8 on the lower bolt the nut is at a place where I can barely see let alone take off. It isn't behind the sprocket cover like it is on some of these other bikes, I don't know how to get to it. Any idea's
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 10-25-2018, 03:33 AM   #52
If you're looking at the front sprocket the nut is to the lower right hand corner. To access it you need to take the chain and the rubber chain aligner off. That should give you enough room to get a socket with an extension in there. Either that or try to get to the nut with a wrench through the bottom.
Hopefully that helps!
Old 10-25-2018, 05:56 PM   #53
Whisky's Avatar
I changed the sprocket it's not there. I looked underneath and I see the nut. It doesn't go all the way through into the sprocket cover.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 11-13-2018, 08:48 AM   #54
chuck   chuck is offline
[QUOTE=p
