08-14-2018, 05:01 PM | #1 |
hawk 250 big bore kit?
I know it sounds silly but does anyone know if theres a big bore kit for a hawk 250?
08-14-2018, 05:44 PM | #2 |
Aren't these engines already a "big bore kit" slapped on a small 125cc engine to bring it up that 229 range?
Might be time to find that "replacement for displacement" (higher compression, port/polished head, smog pump boosted, 4 valve 223cc OHC engine swap, etc.)
08-15-2018, 10:12 AM | #3 |
I've not heard of one and as Azhule points out, these started as a 125. That said, they did take the small block Chevy all the way to a 400!
I figure one of our resident parts guys (mjstef or NZ) may delve into this someday. They'd probably sell one to every CG rider here.
08-15-2018, 11:35 AM | #4 |
There are larger CG motors (in the 270 range, rounded up to 300), but that's liquid cooled territory. I haven't seen one that size that is air cooled.
Search Taobao for CG270, CG300, etc. Get creative with the numbers you search for and you'll find some cool stuff.
08-15-2018, 09:08 PM | #5 |
folks are overbore / stroking horror freight $99. pull start 212cc's surely the hawk 230 is due for a "kit"...
08-15-2018, 09:17 PM | #6 |
Not worth it for the price. Need a custom piston kit 300 custom head gasket 45 bore hone deck cylinder 100 balance crank if need mallory could be as much as 200 how much would you like to spend for 10% power gain?
08-15-2018, 09:19 PM | #8 |
Cylinder only so thick resleeve cylinder probaly 200 more.
08-15-2018, 09:22 PM | #9 |
Wiseco minimum order 4 pistons 900+ dollars cant remember exactly.
08-15-2018, 09:58 PM | #10 |
As far as harbor freight or box stock project lifan motors around 16 hp the cylinders separerate from the block which is one piece. Honda blocks are stronger a little we run them in go cart racing a couple years ago. Was suppose to be cheap they changed rules every week. Till the cost was the same as a briggs animal motor.
08-16-2018, 12:06 AM | #11 |
Wow
08-16-2018, 12:50 AM | #12 | |
The Hawk or CSC TT 250 only run the base model push rod engines etc. There is a 300cc push rod motor that's water cooled and suitable for the 3 wheel trikes but that would work out rather complex |
08-16-2018, 06:58 AM | #13 |
Hawk 167fmm motor not a bad platform for tinkering. I got a aftermarket head for mine night and day difference in ports id say 1 hp no porting i can stick my whole finger in ex port where a stock hawk only 3/4 inch in ex port. I would like same motor just do some good old boy tricks most dont have a clue about you be supprised. Id also like to get mine on ethonal for cooling purposes since we got a big gas tank i think i could still have a 180 mile distance all id ride in a day.
08-16-2018, 07:59 AM | #14 |
Porting and decking the head will get you some extra ponies along with free flowing exhaust and better freer flowing carb.
08-16-2018, 03:02 PM | #15 | |
