04-30-2018, 08:38 PM | #1 |
Bashan storm gas cap siphoning???
Any one have a cure ??,,the locking gas cap sticks over an inch down into the tank ,,,and if you fill up enough that gas touches it ,it siphons gas out till the levels down.Any cure other than only filling tank 3/4?
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
04-30-2018, 10:20 PM | #2 |
I haven't noticed it and I just top off the tank this weekend, I'll look for that but I don't take it to the top of the cap usually.
05-02-2018, 10:58 AM | #3 |
I just dont fill mine up all the way. It breaths through the cap.
Bashan Shark, Keihen PZ30 Carb, Pilot 40, Main 120, Uni Filter, Exhaust, MSR Shifter, and some stickers. |
05-03-2018, 03:37 PM | #4 |
I have the same issue it sucks I can not fill the tank any where near full. Maybe need a different cap?
2016 Brozz |
05-03-2018, 03:43 PM | #5 |
Doesn't Bashan Brozz, Shark and Storm have the same gas cap as the Hawk? Never had a problem and I fill mine to the top. Looks the same from the outside. Is the part that goes in the tank Longer than on the Hawk?
05-03-2018, 04:19 PM | #6 |
That looks just like mine, I haven't had any problems with it.
05-03-2018, 04:34 PM | #7 |
May have to drill a small hole closer to the top to break the siphoning effect.
05-03-2018, 10:29 PM | #8 |
My sharks gas cap does the same tuning, I'll try drilling a hole close to the top to see if it helps. Its frustrating because I lose about a half gallon of capacity
05-04-2018, 07:28 AM | #9 |
Drill a small hole in what? The tank? Where is this small hole located on your bike
2016 Brozz |
05-04-2018, 07:48 AM | #10 | |
05-04-2018, 07:53 AM | #11 |
This one. http://chinariders.net/showthread.php?t=19459 Drilling the small hole should accomplish the same thing. anything to stop the siphoning effect
05-04-2018, 09:58 AM | #12 |
I will give drilling a small hole in the cap a try.
Thanks
2016 Brozz |
05-07-2018, 07:01 AM | #13 |
I decided to take the dremel to the cap with a cut off wheel I took off around an 1 inch of it. It now ends right at the level of the locking teeth.
If it still gives me grief I will also drill a hole in it
2016 Brozz Last edited by goat67; 05-09-2018 at 07:24 AM. Reason: typo |
05-08-2018, 07:25 PM | #14 |
Storm gas cap
Yes,, please let me know the results ,!I love my storm,but this filling up 3/4 sucks ,,an forgetting an filling it up the whole way,an wearing gas sucks worse.
05-09-2018, 07:26 AM | #15 |
I will keep ya posted rainy all this week not getting to ride it to work.
Next time I fill it up we will see what happens.
2016 Brozz |
