Old 04-02-2018, 12:16 AM   #1
powerband_junkie   powerband_junkie is offline
gio gx 250cc/apollo rx 250 carb options
i was wondering what kind of carb to put on my 2017 gio gx 250cc I'm getting, I think its the same bike as the Apollo rx 250cc, the bike is coming with the pz30 carb and I been reading that there crap, can even get the bowl off without cutting slots in the screws please help!
Old 04-02-2018, 05:12 AM   #2
Not sure if the variants of the Tao Tao bikes have a sealed carb. The PZ30 itself is not a crap carb. The reason you see a lot of people switching to the Mikuni is more often to not have to deal with the sealed carb OR just the ease of tuning since there are so many people running them, and thus many examples to help start off with.
If you sit the Mikuni clone and PZ30 clones side by side, aside from a couple of differences, they are pretty much the same carb. 3 vs 4 bowl screws, Mikuni vs Keihin jets, and the choke lever works in the opposite direction... and that is about it.
Some advantages of the PZ30 carb are that, since it uses the Keihin jets, there are a lot more "inbetween" options in terms of jetting, allowing you to really dial in the carb tuning a little better if you so desire. The PZ30 also comes in a "pumper" version, which when tuned properly can make for a bike with nearly instant throttle response, and the ability to really dial in the tuning even more on the main and needle jets.
Old 04-02-2018, 04:39 PM   #3
thanks for the info magadan clears a lot up for me with the pz30, had bikes before but never had a Chinese bike before this is the first for me.
Old 04-02-2018, 05:33 PM   #4
Its_not_a_honda   Its_not_a_honda is offline
https://www.ebay.com/itm/PZ30-30mm-C...bba0%7Ciid%3A1
This is a "pumper" carb I found on ebay. I have already ordered one from aliexpress before I saw this one on ebay. I have a 2017 Apollo 250 that I just got in Jan 2018. Should be the same bike as mentioned in this thread. I will post pics and let everyone know how it goes.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 04-02-2018, 07:18 PM   #5
Douglass   Douglass is offline
Douglass's Avatar
MegaDan, Can you make a suggestion to what pumper to use for the Apollo 250RX? I purchased the Mikuni 30mm, but if this is better, I would rather try it out. Also, would you start with the same jetting as the Mikuni? I think I have mine at 27.5/117.5 at sea level, but am considering starting with a 30/120 if that helps.
Old 04-02-2018, 11:06 PM   #6
Just search pz30 pumper carb on ebay or aliexpress. I wouldn't say it is "better" but if you have the patience to get it tuned properly it will make for a more reaponsive engine. The inverse ia, it will also drop your fuel economy a tiny bit. They do require a double ended throttle cable, so make sure it comes with the right length you need, or order the right one seperately.
Old 04-03-2018, 12:48 PM   #7
Douglass's Avatar
Thank you for the reply. I'll try the Mikuni first. If I want more I'll try the pumper Carb. Appreciate the help!
Douglass
