Old 03-29-2018, 09:14 PM   #1
par1   par1 is offline
storm headlight
hi does any body know if i can change out the stalk headlight on a storm 250 for the one on the brozz ?
Old 03-30-2018, 12:24 AM   #2
china007   china007 is offline
If it's the same is the enforcer then no. The wiring harnesses and front fender are all different and you have to make a new mount.
Old 03-30-2018, 12:02 PM   #3
XDoubleXA   XDoubleXA is offline
XDoubleXA's Avatar
Yeah, I have a Bashan Shark and I can't find a plug and play LED for it.
Bashan Shark, Keihen PZ30 Carb, Pilot 40, Main 120, Uni Filter, Exhaust, MSR Shifter, and some stickers.
Old 03-30-2018, 05:24 PM   #4
thanks for the help.
Old 03-31-2018, 08:24 PM   #5
i am looking to just change out the shroud for looks . i would not mind using the storms bulb and wiring.
Old 04-01-2018, 05:51 AM   #6
humanbeing's Avatar
Originally Posted by XDoubleXA View Post
...can't find a plug and play LED for it.
Good old HL is easy
Old 04-01-2018, 11:00 AM   #7
Cravin01   Cravin01 is offline
Cravin01's Avatar
Humanbeing
Is that a kit ? do you have the link or tell me the name of it, HL ?
Old 04-02-2018, 05:55 PM   #8
Cravin01's Avatar
Found it.
https://www.amazon.com/dp/B00UX5WRBM..._t2_B0764DSQRX
Old 04-05-2018, 07:37 AM   #9
XDoubleXA's Avatar
Originally Posted by Cravin01 View Post
Do you have to cut the wires on that, or will it just plug in?
Old 04-05-2018, 11:11 AM   #10
Cravin01's Avatar
I don't know, I haven't bought it yet but it's only three wires to deal with so it should be simple enough. The part that mounts in the housing is the most important I'm guessing.
Old 04-13-2018, 07:16 PM   #11
Cravin01's Avatar
This kit I bought has needed some modifications to make it work due to the Storms housing.
The mount with two tabs needed to be grinded down and glued in the housing to mount the Led, It does not lock in at all. the wire harness needs to be replaced also.
Make sure the Led is in a upright triangle when it is in the housing at the time you glue in the plastic mount.
The Led has two sides on a angle that are the low beam and the bottom is high, it must be positioned correctly.
I might replace the harness on the bike so I can just buy a replacement bulb and not rewire each time.
This is a really simple thing to do. I wouldn't let it stop you from upgrading and this kit has everything you need to do it.
