Old 12-12-2017, 02:22 PM   #1
richinar   richinar is offline
Hawk 250 - replace gearshift spindle
Sooo
The shift lever broke on my Hawk yesterday after a slow low side yesterday. Not the pedal, no, no, but the lever rod itself just inside of the splines. Twisted right off. This is a stock pedal clamp with my own bolt. Suspect I shouldn’t have used a bolt that wouldn’t strip out and allow the clamp to shred.
Yay!!!
Who carries stock engine parts and is responsive? Does the TT250 engine match?
File Type: jpg 799C1425-E0CF-4223-92D2-BD984036E3BA.jpg (9.9 KB, 418 views)
Old 12-12-2017, 02:41 PM   #2
The TT250 looks like a possible match but not sure. Check with TXpowersports
2020 Kawasaki Vulcan S
Old 12-12-2017, 04:44 PM   #3
Ah. I didn’t see that Txpowersprt had the Hawk
I have been in touch. I bet that’s it.
In cracking into this I’ll need a book.
Which Honda engine should I look for a manual on?
Old 12-12-2017, 04:55 PM   #4
I have two manuals I can email you. PM me your email address and i'll send them to you.
Old 12-12-2017, 05:59 PM   #5
Thanks a ton
So, could I presume that a CG125 gearshift linkage and spindle will also fit? A Honda part would ease my mind.
Old 12-13-2017, 08:39 AM   #6
Thanks a ton
That I could not answer unless I had one in hand to take measurements.
Old 12-13-2017, 09:21 AM   #7
Yeah. I’m gonna pull it and take with me to the Honda dealer this morning.
Will have part numbers handy from offshore vendors where the CG125 motor was quite plentiful.
Old 12-13-2017, 09:31 AM   #8
Good luck, hope it works out.
Old 12-13-2017, 10:08 AM   #9
franque   franque is offline
You're better off going to a China bike dealer. Honda dealers in the US can't get parts for things sold overseas... My friend, a parts manager at one, was looking into getting black CRF250L bodywork, and basically was going to have to order it from Thailand, from a Thai dealer shipped to his house to get it. That being said, I have access to in-Honda, their online parts catalogue, and I could probably let you know if there's any cross reference with a USDM model(most parts guys don't know how to do that). My guess is that there could be interchange between a cb125 and your bike, assuming it is a 5-speed with a conventional shift pattern.
Old 12-13-2017, 11:03 AM   #10
Right I was thinking CB had same crankcase as drawings “appear” “similar”. Although conventional wisdom states the CB125 ceased US sales in ‘85.
TX Poweraporta didn’t have the part and are checking with supplier. Ricky’s has not responded to requests through email, phone, or PM here with Adam.
the part goes by different names depending on the source but “gearshift spindle” appears to be the more forthright convention. Looking at my setup and the resulting damage I feel I may have also put the pedal at to dramatic and angle to the clamp, forcing a twisting shear. I took some close ups of the spindle failure and it appears the metal had a lot of flake/impurity, not surprising.
File Type: jpg 3A2EFB9C-DA27-4D29-9E8F-CB47D7AEEA79.jpg (9.3 KB, 398 views)
File Type: jpg 60276BA0-BFFC-415D-9AC7-B565D396A030.jpg (10.6 KB, 397 views)
Old 12-13-2017, 11:14 AM   #11
You could call CSC and have them verify a few measurements like shaft diameter and length as I think it would be a match. Worth a try.
Old 12-13-2017, 12:32 PM   #12
24610-107-760 Is the part number for all of the vertical (OHC XL, CL, SL, CB, TL, NX, and CT) 5-Speed 100-125 singles sold in the US up to 1989 (but not the XR100, that's a different motor all together). It appears that it is still available on IN, but I'd call a dealer just to double check, because sometimes it appears available until you order it.
It is possible that it is a different length than the one that you are working with, solely based on the fact that it is kick and electric start (the electric start side cover is a bit wider, but I don't think it is wider right there). It should cost $50 or less. XR200s are different, at least in terms of part numbers.
Old 12-13-2017, 01:17 PM   #13
pistolclass's Avatar
Any chance you can weld it up until you find a replacement?
Old 12-13-2017, 03:11 PM   #14
Local dealer had no new but did have a used part - in fact, they had 3!
$20.82 including tax
have test fit everything and its a perfect match
Honda is shorter by a pinch - not a problem at all
the big difference is the spindle material
will post detailed side by side comparison later
THANKS for the help!!!
‘16 Hawk 250 changed up a bit
‘85 Virago 1000 changed a bit more
Old 12-13-2017, 03:14 PM   #15
Local dealer had no new but did have a used part - they had 3!
That's good to know. You and franque have uncovered valuable information. Another part number to add to list.
