12-06-2017, 07:22 AM | #1 |
Viva 200cc stuck is 5th gear!!!
So i just replaced my battery n went for a gentle cruise. After 5 mins of riding i went to downshift and noticed i couldnt. Shift out of 5th? Is this a common problem ? And anyone have a video of repair or clutch cover removale? Its my first bike and not 100 percent how it works
12-06-2017, 08:26 AM | #2 |
This is a tutorial for a CSC TT250 but will be very similar process to you engine. https://www.cscmotorcycles.com/Articles.asp?ID=301 PM me your email and I have a couple manuals I could send you.
12-06-2017, 08:50 AM | #3 |
Thanks man i appreciate it
12-06-2017, 08:59 AM | #4 |
No problem, I emailed 2 manuals. Hope they help.
12-06-2017, 10:40 AM | #6 |
That would be on the shifter side of the motor?
12-06-2017, 10:46 AM | #7 |
Yes, sometimes those bolts will back out just enough to get in the way of the shifter.
12-06-2017, 10:46 AM | #8 |
Have you had this problem?? Wanna pin point before i start breaking it down
12-06-2017, 10:52 AM | #9 |
Jerry, would the 24 hr tip over plate soak trick affect this? Just asking
12-06-2017, 11:21 AM | #10 |
From what he is describing , he can't shift out of 5th gear. It could be something simple as something obstructing the shift lever to a stopper plate bolt or pin broken or lose or dislocated.
12-06-2017, 11:22 AM | #11 |
You have a picture of the sprocket cover...sorry man im learning as i go
12-06-2017, 11:24 AM | #12 |
It's the cover over the front chain sprocket on the left side of the engine.
12-06-2017, 11:37 AM | #13 |
Another member had a similar issue. This may help out. http://chinariders.net/showthread.php?t=20032
12-08-2017, 08:58 AM | #14 |
Jerry. Today i wanna start breaking down everything. But before i start does anything look wrong with the shifter??
12-08-2017, 09:36 AM | #15 |
It doesn't look like anything stopping it from working there. I would pull the right side cover off and inspect the shifting mechanism. Make sure nothing is out of place.
