Old 10-25-2017, 11:50 AM   #121
Mike, you can just search www.taobao.com and use CG200 as your search phrase. Use Google Chrome and allow it to translate automatically. After several pages, you'll eventually find some interesting pistons for cheap.
Old 10-25-2017, 10:16 PM   #122
Ironmike   Ironmike is offline
Thx for the link. I ended up buying new valves/springs/seals. Good or bad idea to replace the valves? Should I just replace the seals?
Old 10-26-2017, 11:41 AM   #123
If they're the correct dimensions, why not replace them? It strikes me as a good idea. You could even lap them into the seats.
Old 10-26-2017, 09:07 PM   #124
I compared the valves today. The new ones look slightly smaller hope valve seals are right? I can just lap the old ones while I have them out. What about opening up the exhaust port a little?
Old 10-27-2017, 12:04 PM   #125
The valve seals are likely to be correct, but it's only a guess. I wouldn't open up the exhaust port, but I'd clean it up. I might even polish it.
Old 10-27-2017, 07:21 PM   #126
To be fair, cleaning up the exhaust port effectively essentially means opening it up. While I wouldn't hog out the diameter of the port exit much, the port itself requires quite a bit of "cleaning" to open it up lol. The casting around the valve guide consumes so much of the exhaust port that it's a bit comical.
Old 10-29-2017, 09:50 PM   #127
Thx for replies. How important is it to clean the centrifugal filter? I ask because previous owner had to extend the kick start shaft by to clear the frame to make it functional. The shaft is welded along with the kick start lever. I ran the motor very briefly with valve cover off and oil is pumping to the top end nicely. Is this an actual screen? Someone plz explain what it does? Thx
Old 10-30-2017, 10:06 AM   #128
Ariel Red Hunter's Avatar
No, it is the opposite of a screen, or paper filter, in the way it cleans oil. They used to call these devices lube-refiners. They work by centrifigal action. As it gets up to speed, it spins the oil at a high rate of speed. Anything heavier than the oil gets thrown into the outer rim of the case, and the now cleaned oil goes on its merry way to lubericate the engine. So it is ESSENTIAL for you to clean it out, especially since the engine had a piston failure. You are going to have to get that shift lever off of the shaft some how. If you don't already have a Dremel type power head, you can buy one online or at a True-Value hardware store. But use a Genuine Dremel die grinding bit, like the guy who just posted about mounting a new exhaust system on his Hawk. You have to get that shaft as smooth as a baby's ass in order to not tear up the kick-start shaft oil seal. Patience, young man, patience...ARH
Old 10-30-2017, 10:19 AM   #129
The kick start weld looks nasty. lol If you don't need the kick start you might just have to wack it off and get another shaft.
2020 Kawasaki Vulcan S
Old 10-30-2017, 08:04 PM   #130
Ok didn't know it was that important. I'm gonna just cut the shaft. I don't use kicker anyway! Thx ARH for the explanation
Old 10-31-2017, 08:53 AM   #131
You're welcome. Be sure you file any burrs after you cut it. You don't want to wait 3 months for a new seal to get here. Going this far, have you checked the rod bearing? It is a roller bearing, and can have a little movement back and forth, but none straight up and down. You don't have to put a lot of effort in lifting it. I used to just put a finger in the piston pin hole in the rod to check it for slop...ARH
Old 11-01-2017, 10:20 PM   #132
I'll be sure the shaft is nice and smooth. The rod has side to side movement with no up/down play. Really take that long for a seal? Hoping to have time Sunday to work on it. The head pipe is def restricting things a bit but want to make sure it runs good before I buy the one mentioned in previous post. Can't seem to find that pipe local. Is Australia is only play available? Thx
Old 11-06-2017, 08:37 PM   #133
Got the motor back together. The valves ended up fitting fine. Did 3 10 min heat cycles per Duncan racing then changed the oil. Adjusted valves. Have 153 psi as of now. Good thing I cleaned out the filter under the side cover. That thing was CAKED with grim/crap. Gonna start riding around the yard to break it in more. Sounds pretty smooth for a push rod motor. After I know it's running good I'll start working on the details. Exhaust it def on the list.
Old 11-07-2017, 11:57 AM   #134
If, as you say, the centrifigal oil-refiner was full of grime and crap, that device is what saved the rest of the engine. Just imagine what that engine would have been like without that thing being on there...ARH
Old 11-08-2017, 08:12 PM   #135
I'm sure your right. I'll post a pic. It's on a grey oil mat so it's kinda hard to see it all. Rode it for 10mins at up to 50% throttle. Running good! The breaking up and having to run it on 1/2 choke is no longer there/needed running way smoother. I will still have to jet it in in the spring. Over the winter I'll do a lot of cleaning up and adding some new parts! Appreciate everyone's help!!!!!!! Oh ya is Australia the only place I can get that head pipe I need?
